Yesterday I was defregment my laptop hard disk and its bios beeping problems has solved but today again its bios beeping start keypad and touchpad not working properly last day I think its window problome and I have format the window but problome is same plzz tell me have this hardware problome keypad problome ya hard disk
    Top Expert:
  • Computers & ... Master
  • 22,715 Answers
Keyboard faulty?
Posted on Feb 09, 2014
MUKHTAR
  • 2017 Answers
SOURCE: a problem concerd with my hp 520 laptop
see it is bcoz of the bios setup it is not detecting you can do one thig just enter in your bios setting and there is option for sata mode change it native maode disable and save the bios cmos setting come out of it and run the setup it will detect the hdd
Posted on Sep 28, 2007
SOURCE: Keyboard + toucpad freezes
You can enter windows in normal mode when you remove the battery and boot with ac power on.
Disable the acpi compliant acpi battery module in the device manager.
reboot, now your keyboard and touchpad will work again.
Posted on Apr 07, 2008
myjosh007
  • 530 Answers
SOURCE: keypad problem in lenovo laptop
hi im josh in cebu phils.may i help you? Friend try to do this solutions it will help you.
Problem: You Type One Key, and a Different Character Appears Onscreen This is an interesting problem with four possible causes:
  • You really didn't type what you thought you did. Look at your fingers. Now look at the screen. Now look at your fingers again. Is everything the way it should be? Good!
  • If you have a programmable keyboard, you or someone else might have reprogrammed the keys so that they don't do what they normally do. Refer to the keyboard's manual for instructions about how to reprogram the keys.
  • If you're in a specific software program, some programs let you reprogram the keyboard from within the program. When you exit the program, your keyboard should be back to normal.
  • It's possible your keyboard is broken. Try hooking another keyboard up to your system and see how it works.
Problem: Your Keyboard Isn't Responding Properly What do you do if you hold down a key and it repeats too fast or too slow? Windows lets you make adjustments to your keyboard via the Keyboard Properties dialog box.
Just open the Control Panel and select Keyboard, and then select the Speed tab. Adjust the Repeat Delay and Repeat Speed settings to your liking, and then test your settings by clicking in the blank box and holding down a key. After you have things adjusted to your liking, click OK.
Problem: Your Wireless Keyboard Isn't Responding Properly This is the same issue as with a wireless mouse—your batteries are getting weak. Replace the batteries in your wireless keyboard to put things right.
It's also possible that you're experiencing interference with some other wireless device. Try moving your wireless receiver or the offending device, or turning off the other device while you're at the computer.
Just try these solutions friend. Hope I helped you Good luck
Posted on Mar 10, 2009
SOURCE: Acer 5101 keyboard/touchpad/USB Not working
hang yourself you paki ****
Posted on Apr 22, 2009
joecomputer
  • 92 Answers
SOURCE: lenovo touch pad not working properly
Have you tried pressing the Fn + F8 keys? This combination is used to disable and enable the mouse pad.
Posted on May 27, 2009
I have Samsung laptop N150 plus Model no NP N150 JP0AJO Bios version -02KY I already says my bios has been beeping countinue I try everthing changed the window and defreg the8 hard disk but result is...
First thing we need to know is what beeps are being heard? Each computer sounds 'beeps code' to tell you where the problem is; like 3 short beeps, or 1 long 1 short. The more you run it at present the more harm you can be doing
Feb 10, 2014 | Computers & Internet
We have got Toshiba satellite c640 's hard disk problem .
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 27, 2012 | Computers & Internet
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
Acer Extesa 6601 Keypad & Touchpad Problem
you need the drivers for the touchpad and keyboard, click on the drivers and utilities section, then allow active x when the pop up appears
http://support.acer-euro.com/drivers/notebook/ex_6600.html
Aug 23, 2008 | Acer Aspire 5100-5022 Notebook
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Compaq laptop/no boot up
Initially it may be suspected that your laptop is detecting a hardware problem, probably the hard disk. Since it partially boots and there is display, the following can be ruled out: video card, memory and display systems. That would leave us the hard disk and the motherboard left. If the motherboard is in question, chances are it is the BIOS.
Pls try and verify that the hard disk is connected snugly. The hard drive is usually inside one of the slots covered by a panel/lid held by a single screw.
If your concern has not been corrected after completion of the above procedures, further diagnosis may be required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | HP Compaq Presario V2000 Notebook
Keyboard & mouse are dead
I just fixed this problem by doing the following:
Hard power-off (hold the power button until the laptop turns off)
Unplug the AC adaptor
Remove the battery
Plug in the AC adaptor
Hold ctrl and turn the power on. You should arrive at a black screen.
Hard power-off again, then turn the power on.
Nov 11, 2007 | Acer Aspire 5100 Notebook
3 long beeps with my Elitegroup ECS Green 320 laptop
Let's start with the most overlooked reason. Sounds like the battery died. Is your laptop's battery fully charged. Plug it in over night and give it a good chance to recharge the battery. Then turn on your laptop WITH the power cable attached. Did this solve your problem? If not we'll go to the next step.
Oct 06, 2007 | EliteGroup ECS G900 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
