Question about Konica Minolta Office Equipment & Supplies
Code m4 minolta - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,674 Answers
Sir/mam model number would help
Posted on Mar 12, 2017
3 Suggested Answers
SOURCE: minolta di 181 error code M4
QUEL EST LA SOLUTION POUR DESACTIVER L'ERREUR CODE M4 ?
Posted on Jul 15, 2011
j'ai un probl?me avec ma photocopieuse Minolta DiALTA Di181 qui me signale comme erreure code M4. Je cherche la solution pour suprimer ce code error M4.
What does the error message C5351 mean on a Konica Minolta Bizhub 200?
Fault Code
C5351
Description
Power Supply Cooling Fan Motor Failure
- The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning.
- The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Remedy
1 Check the M4 connectors for proper connection, and correct as necessary. 2 Check the fan for possible overload, and correct as necessary. 3 M4 operation check PWB-A PJ33A-1 (REM) D-5 4 Change PU1.
Oct 28, 2016 | Minolta bizhub 200 All-In-One Printer
How do clear a m4 code on a minolta cspro 4000
please open the back side cover press the motherboard reset button .
Jun 12, 2014 | Minolta EP4000/5000 CS/PRO Copier
Codigo M4
Maintenance counter needs to be reset in service mode. meter count stop0 stop1 or just stop0 stop1
Jan 22, 2014 | Minolta EP4000/5000 CS/PRO Copier
M4
I have a machine konica Minolta always appears incorrect code C-2703 I wanted to know what the cause of the problem and how to solve
Dec 15, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
Code m4
m4 = maintenance counter 4 reset
Jul 17, 2012 | Minolta EP4000/5000 CS/PRO Copier
MY MACHINE DI 181 SHOWS SERVICE CALL M4 AND DOES NOT COPY
This M4 code means that your drum life is over. You have run 80,000 copies or more on the drum. If you have a local service company available then I would just have them come out and clean the machine and reset the counter. This is especially true if your copies were still fine prior to the machine shutting down. Service mode entry and navigation is rather complicated on this machine so I do not feel comfortable trying to walk you thru the reset process.
Good Luck and Thank You for using Fixya.
Jun 10, 2010 | Minolta DiALTA Di181 Printer
Minolta di 181 error code M4
Jan 21, 2010 | Minolta DiALTA Di181 Printer
Konica minolta 1216
1. A fan irregularity signal, excessive current draw due to binding. Examine M4 for obstructions which may bind the fan. Check the M4 fan lock signal (main CB, CN26-4) in the 47 mode, input code 42. The voltage should be between 0.1 to 0.2V DC. If 5V DC is present, either the fan is binding or the fan is defective. Replace M4 (p/n 25HA80512).
Note: If the fan lock signal is normal, install the version 17.0 EPROM (p/n 101517-17.0) to prevent false F54 errors as outlined in 1015/1212 Technical Bulletin #15.
2. IC7 on the main CB has shorted due to a failed total counter. IC7 shares the 24V DC control signal line with the exposure lamp, separation solenoid (SD1), registration solenoid (SD2), total counter, key counter, and cooling fan (M4). All loads except the total counter operate in diagnostics.
Replace the total counter (p/n 466088201) and the main CB (p/n 25HE-7312).
3. A poor connection between the cooling fan (M4) and the main CB. Reseat CN73 at M4 (cooling fan) and CN26 on the main CB.
Dec 19, 2007 | Office Equipment & Supplies
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
