Question about Danco Faucet Stem
How to install a danco 10472 4z-24h/c hot & cold faucet stem
How to install
  • Guildo Thibault Jun 19, 2016
    How do you install the cold water valve so it turns clockwise?
    Top Expert:
  • Danco Master
  • 34,725 Answers
  • Shut off water supply
  • Open faucet
  • Remove knob
  • Unscrew old stem
  • Use flashlight to inspect seat for damage and corrosion. Dress or replace seat if necessary.
  • Install new stem
  • Reinstall knob
  • Turn on water supply and check for leaks
Posted on Jun 20, 2016
  • 297 Answers
SOURCE: how does a 9s-4h/c danco stem install.
the spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of takeing off.
Posted on Jul 27, 2009
  • 67 Answers
SOURCE: I bought a Danco 3H-10H/C, Hot/Cold stem. The
One of two things has happened. I'm assuming you only get hot water when you open the valve and that this is for a single handle control shower fixture. If so either this is the wrong valve for your shower control or it is installed backwards. Sometimes the valve can be installed at either 180 degree angles. See if it can be installed any other way. If so this may solve the problem.
Posted on Jul 19, 2010
  • 70 Answers
SOURCE: Where does the spring and rubber piece go when
http://kitchen-bath.hometownhardware.com/Faucet_parts-ssd70982-p9-l1-t1-Sv-dirasc-PP10.html
Posted on Aug 15, 2010
  • 15 Answers
SOURCE: I HAVE A DELTA FAUCET
order a moen replacement online from
www.plumbersurplus.com/Prod/Delta-Faucet-Company-RP24096.
Posted on Sep 17, 2010
SOURCE: Where does washer go for 12h-6h/c stem from Danco for faucet?
If it is red in color it is a #38 fiber washer and is the cap thread gasket.
Posted on Jan 06, 2011
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
Faucet still running
Change the O rings in the mixer.
Mar 10, 2014 | Danco Faucet Stem
Bathtub faucet knobs for cold hot and shower knobs
If you are looking for replacements, Home depot and Lowes both carry Danco replacement
knobs and stems for many models in the plumbing department as well as remodel kits
for Delta. Hope this helps.
Feb 26, 2011 | Plumbing
I bought a 3h-10h/c but it only works for hot. do you have the same product for the cold side?
The same part works for both Hot & Cold sides. Usually preset to work on Hot (counter clockwise on, clockwise off). To set for Cold, simple remove the plastic clip from the top, slide the ring tab off, flip it over and put back on (you can only put it on one way since there's a flat "key" in it matching the stem) Now its set for Cold (CCW of, CW on). HTH
Aug 05, 2010 | Danco Faucet Stem
I bought a Danco 3H-10H/C, Hot/Cold stem. The problem is, it seems to be setup for hot (clockwise closes the valve, counter clockwise closes it). Is it reversable? Or is it not really a hot/cold...
Jul 18, 2010 | Danco Faucet Stem
How to insert a hot cold ste, 3Z-6H/C FAUCET REPAIR
#1 THE FAT PART OF YOUR SPRING GOES INSIDE THE FAUCET ,AND SIT ON THE VALVE BODY(SEAT)
#2 THE LITTLE BLACK WASHER SIT ON TOP OF YOUR SPRING
#3 PUSH THE STEMS IN THE CORRECT SIDES HOT ON LEFT.CAUTION THERE IS USUALLY NOTCHES ON THE SIDES OF THE STEMS TO HELP YOU ALIGN THEM IN THE VALVE BODY,
4 PUT THE NUT BACK ON ,TIGHEN SLIGHTLY,TURN ON THE WATER TO CHECK ,IF OK RE INSTALL YOUE HANDLES
Apr 06, 2010 | Danco Faucet Cartridge
I bought a replacement Danko faucet cartridge for an american standard bathroom sink and the package said hot/cold but when I installed it on the cold side the handle turns the wrong way. How do I reverse...
Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
Dec 29, 2009 | Danco Faucet Cartridge
How does a 9s-4h/c danco stem install.
Apr 08, 2009 | Danco Faucet Stem
Replacing stems on old hot and cold shower valves
Some times the seat gets worn anout of round. there is a tool you can buy called a faucet reamer or reseating tool. this shoul help thanks
Oct 12, 2008 | American Standard Plumbing
Danco Faucet Stem  Logo
844 people viewed this question
Top Danco Home Experts
Donni Steen
Andrew Bugbee
richie46
Are you a Danco Home Expert? Answer questions, earn points and help others
