Question about Marantz SR4002
Power light flashing
Unit can't turn on
    New Friend:
Press s.speaker b, att, and exit in 3 sec
Posted on Feb 19, 2015
Fujitsu heat pump flashing code?
Test the fuses for the outside unit.
Aug 29, 2017 | Heating & Cooling
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Mitsubishi air conditioner flashing timer light flashes twice
Switch the polarity of the control voltage...make sure it matches with the indoor & outdoor unit
Dec 18, 2013 | Mitsubishi Heating & Cooling
What is the difference between the flash and continuous lighting, why not using continuous lighting for photography?
Two main reasons flash is used over continuous lighting.
Power. Lighting a scene for minutes uses much more power than lighting it for a fraction of a second. You may have noticed that most continuous lights need to be plugged in to a power supply, while most flash units work with small batteries. It may not make much difference if you're shooting indoors in a studio, but if you're out in the field and have to move around, it can get difficult lugging all that gear around.
Duration. A flash unit provides a very brief flash of light while a continuous unit is, well, continuous. A flash can freeze action much better than just using the camera's shutter. Try it yourself sometime: turn on the lights in the bathroom (and/or bring in your continuous light units) and take some pictures of a dripping faucet. Now turn off the lights and take some flash pictures of the same thing. See the difference?
Dec 17, 2013 | Photogenic DigiLight Continuous 500 watt...
When you turn it on The blue light flashes and it returns to the red light and will not turn on
This is a power problem from the unit. The unit receives power into it but does not supply the power sufficiently enough to get the unit to function well. This is why the blue light flashes when the initial burst of power is sent into the unit but due to lack of follow up power the unit fails to remain on.
Best get an expert to identify if the power supply distributor in the unit is bad or the ic which is responsible for the distribution is the cause.
Hope this solution has been helpful?
Apr 10, 2011 | RCA RT2870 Theater System
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
I have a 2005 Mitsubishi HD1080 big screen that today, when I turned it on, the power light comes on, flashes but the overall screen never come on. Turned & unplugged the power for awhile to see if...
Hello:
There is a problem within the digital board assembly. This is the metal can like unit to the left side of the unit when looking inside it with the back off. The power management is inside this unit. There are 7 1000uf 16 volt capacitors on this small power supply that needs to be replaced. The pwr board is the first you see after opening the Digital unit. Replaced the capacitors with 680uf 16v capacitors instead of 1000uf. After replacing the capacitors looking thru the holes in the digital assembly there will be a green flashing LED, Watch this light for a moment, should stop flashing and stay steadily green if all is normal. Also the power light will still flash for at least 60seconds then go off. Turn on power and happy viewing...Cost to repair this should range around $200-250.00 dollars.
Thk Please leave message...
Oct 07, 2009 | Televison & Video
Flashing power lamp
HI, the power unit has failed. you will need to replace this failed power unit if possible.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Jun 03, 2009 | Sharp LC-26D43U Television
Marantz SR4002 Logo
174 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
