Question about Harman Kardon Audio Players & Recorders
1610 stay at sleep mode
My harman kardon receiver avr 1610 going into divice sleep mode what I have to do?
    Genius:
  • 1,175 Answers
SOURCE: Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Followup on higlider's problem. Now it has to be turned on ten times before it stays on. Email from Harman Kardon only suggests taking it to an authorized repair shop. It is clear that it is not from speaker short or overheating, because it only happens when the rcvr is cold.
-higlider
Posted on Jan 05, 2008
  • 4 Answers
SOURCE: I have a Harman Kardon AVR 235 Receiver that go's into Protect
To avoid making the avr go into protect mode when you power up your Hafler 4000 that is connected in the avr's pre-out, you must power up the set up in the correct sequence.
1. Turn off your avr
2. Connect Hafler 4000 to the avr's pre-out it it is not yet connected
3. Turn on your Hafler 4000. The avr will not go into protect mode becasue of the transients from the Hafler because it is still not powered on.
4. Turn on you avr. There should be no more transients from the Hafler at this stage unless it is not functioning correctly, so the avr shouldno longer go into protect mode.
Posted on Dec 16, 2008
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
SOURCE: My Harman Kardon AVR 330 is locked. Can't unlock
youtube
myspace
facebook
Posted on Feb 12, 2010
AJIN G
  • 6694 Answers
SOURCE: Harman Kardon receiver in protect mode. Removed
hi,
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Noramlly AV receivers show this when any of the output amplifier get some problem. there are six amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
for that you need digital multimeter,soledring iron screwdrivers etc
open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Posted on Feb 12, 2011
AVR 1610. Why is it stuck in sleep mode?
Get a owners manual online and try resetting/rebooting the reciever. Most newer receivers have a reset code which clears
some of these issues - the reset code usually involves pressing a series of buttons on the front panel of the receiver.
If this doesn't work buy another one used on e bay as it will be much cheaper than hiring an electronics shop to tear the receiver apart. Most shops want money upfront and don't guarantee the repair. Plus you will be listening to music much quicker as the shop will have to procure parts.
Dec 24, 2013 | Harman Kardon Audio Players & Recorders
How do i reset an harman kardon avr-310
There is no reset for it, If it doesn,t stay on something is wrong with it,End it has to be taken in for repair,
Nov 01, 2012 | Harman Kardon Audio Players & Recorders
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Dec 08, 2008 | Harman Kardon AVR 235 Receiver
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
317 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
