Question about DCS RDU-305-L Range 30", 5 Burner, LP Gas
DCS igniter problems - DCS RDU-305-L Range 30", 5 Burner, LP Gas
Dcs 484 oven won't light but ingition bar glows bright
Yep, that's a common problem with these stoves. The igniter has a limited lifespan. You will need to call and order another igniter and probably have someone install it.
Dec 29, 2013 | DCS Kitchen Ranges
DCS oven does not ignite
Sounds like it could be the solenoid.
Apr 22, 2012 | DCS 36SP Kitchen Range
DCS CT365SS igniter wires?
no not standard. but you can replace them if you know a good place to buy high temp wires. If not buy the upper wire harness for the range and the igniter wires will be in that.
Jan 06, 2012 | DCS Cooktops
DCS Cooktop CTD-365 one burner won't ignite/no spark or ticking. I cleaned ignitor.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 11, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Problems with DCS cook top ignitors...PARTS?
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
heatman101
Jun 20, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Dcs 48" gas range igniter comes back when set on low/simmer
This is not a solution but something to think about for troubleshooting.
On the DCS there are two ports that feed gas to the burner.
One for high flame and one for simmer.
On the DCS if the flame is snuffed out on simmer it will automatically reignite.
So if the igniter will not shut off while on simmer, the sensor is bad and is trying to reignite the burner.
May 11, 2009 | DCS 24-24G-1 Gas Kitchen Range
I have a 15 year old DCS 4 burner gas stove and oven. Slide in. The broiler stopped working today. Is it the broiler or the fan? How much are parts?
the likely cause is the hotsurface igniter has failed. not exactly sure how to check the part but you can check it voltage is getting to the igniter. if you have voltage, it's probably the problem.
Mar 20, 2009 | DCS CMO-24-SS Convection/Microwave Oven
Broiler not working, Oven OK
We have a DCS RG-366 SS L, a 36" gas range and the igniter went out. You could smell gas and the igniter would glow red - but no fire across the broiler.
There is a place in Michigan called RepairClinic.com. We bought a replacement igniter from them and it works like a charm. It was $53 (we live close by and didn't have to have it shipped).
The item number (from the invoice) is 1191 and the box the igniter came in looks like it is manufactured by FSP, code 082005, and there is a larger number on the box that says 786324 IGNTR-OVEN.
Hope this helps.
Sep 13, 2008 | DCS RGS-305 Professional Gas Kitchen Range
Igniter will not shut off on my DCS RGS-366 gas range
Replace the multipoint gas re-igniter, it is a blue unit behind the knobs. This unit detects the flame and stops the clicking. Call Fisher and Paykel (owners of DCS) at 1 888 936-7872, they sell parts for DCS. The old inferior unit is blue and has a whte label. The newer unit has a yellow label.
Jul 23, 2008 | DCS RGS-366 Professional Gas Kitchen Range
Stove beeps
it's the igniter, just had that problem. cost me $70.00 for a service guy to tell me since DCS is no help on the phone.
Jan 15, 2008 | DCS RDS-366 Stainless Steel Dual Fuel...
DCS RDU-305-L Range 30", 5 Burner, LP Gas Logo
69 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
