Question about Vans Winter Sports
Gmc safari heat
Car blow cold air not heat how can I fix to get hot air?
  • 958 Answers
SOURCE: 2005 GMC air conditioning
hello wwwatkin,
i stated my post in the clarification post and you can not rate my solution and since rating is just as important to us as answering your questions, can you please rate me in this post?.
thank you in advance and i really would appreciate it if you rate me a fixya.
again, thank you,
drcool299
Posted on Sep 23, 2008
dgjtex
  • 405 Answers
SOURCE: After car heats up (slow to heat) it stil blows cold until moving
http://www.fixya.com/cars/t1386554-91_ford If this doesn't help you tell me more, if it does, please vote me fixya, otherwise please do not give me any rating at all, the only compensation I get is my Fixya score, Merry Christmas.
Posted on Dec 22, 2008
emissionwiz
  • 76846 Answers
SOURCE: Heat on, blows cold air on passenger side
u will need to repair the passenger side air temp control blend door, either the door is stuck or the small electric actuator that moves it is defective.
Posted on Jan 14, 2009
honeymokey
  • 3113 Answers
SOURCE: air blend door
Replace the broken actuator.
Posted on Apr 15, 2009
  • 15 Answers
SOURCE: ford ka heater blows hot air all the time
Your problem is a faulty heater control valve. The design used on these vehicles allows for hot water to flow constantly and compete with the evaporator as there is no blender door. You have to replace the valve and possibly the control head. Meanwhile, you can bypass the valve to have cold air
Posted on Sep 12, 2009
Vents won't blow hot or cold air. Comes from defrost and feet when you put fan on.
It's the vent actuator, it moves the baffle that changes the direction of the air flow.
Here is a video of a broken vacuum hose that creates the same problem.
It could also be a failed actuator.
Sep 19, 2016 | 1997 GMC Safari
Blows cold air turn heat on
Search Results
    07 Tucson heater blowing cold air - Hyundai Forum - Hyundai ...
    www.hyundaiforum.com > ... > Vehicle Line Up > Hyundai Tucson
    Dec 16, 2009 - I have a 2007 Tucson, when you turn on the heater it only blows hot air... Join Date: May 2005 ... a low coolant level will exhibit the first stated symptoms of no heat/low heat at idle and increased heat at cruise due to an air ...
    Denlors Auto Blog » Blog Archive » Car Heater Blows Cold ...
    www.denlorstools.com/autoblog/.../car-heater-blows-cold-auto-service-ti...
    Oct 10, 2009 - When a car heater blows cold air, there are several possibilities that should ...... On my Dodge Neon when I turn on the heat it blows out cold air.
    Heater blows only cool air...even w/ defroster on : Buick ...
    repairpal.com > Problems > Buick > LeSabre
    ... Cadillac, Chevrolet, Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer,Hyundai, Infiniti, Isuzu, Jaguar ... I'll turn up the temp on the dual control to get heat,
Jan 28, 2016 | 2005 Hyundai Tucson
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
2002 gmc safari van defrost blow cold, a/c blow out of defrost
open the hood and check for leak on any plastic vacuum lines.
Oct 19, 2012 | 2002 GMC Safari
Only Blows Cold Air
heat sensor for radiator fan switch, thermistat,water pump? Does hot air blow when moving? does car over heat when sitting idling for over 10 minutes. If so check fan first, then water pump. last cause thermisat
Mar 07, 2010 | 1998 GMC Safari
Why is the heat blowing cold air but at a really high idle it blow hot air for little period of time.the temp of the engine is 195degrees. all the fan controls and the temp control is in the hot position
you could have a couple things going on. possible low coolant? most likely cause as i assume you have checked coolant level would be heater core restricted. to fix this you remove heater hoses and back flush heater core with water. if this does not do it you may have a water pump not circulating at idle but this usually comes with vehicle running hot at idle.
Feb 16, 2010 | 2001 GMC Safari
97 safari fan does not blow while on heat, ac, hot, cold any speed, fuse (well labled) is good. Thx in adv.
Check to see if is blowing out defrost vents if it is you have a vacuum leek. The tube is hard to get to take of dog house you will see a group of tubes on connected to a clear plastic junction. Once you get the dog house off one of the tubes goes to your manifold vacuum fallow them its very thin and the engine heat makes it brittle and they fall apart . Mine did same 2 shops 500 dollars and they never found or fixed it used window washer tubing to fix 2 years ago still works great,
Nov 08, 2009 | 1997 GMC Safari
AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
Aug 25, 2008 | GMC Sierra Cars & Trucks
Winter Sports Logo
81 people viewed this question
Top Vans Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Vans Winter Sport Expert? Answer questions, earn points and help others
