New GE Hydrowave does not fill with enough water even after the pressure sensor was replaced.
Washer has never put enough water in for a full load of laundry. Small size load you get half a tub and runs for almost 9 min. any other load size puts in less that half and runs for a shorter amount of time. The ge repair guy stated my water pressure was too low, that I needed 20psi. So we had new water lines run to the upstairs and the house pressure switch is 35psi. (I am on well water). The repair guy came back and ordered a new pressure switch for the washer as I new there was one and mentioned it the person on the phone. The third time a guy came and replaced the switch it did not make a difference in how much water ran into washer.. Any other ideas would be great.. I really hate having to babysit the washer because of having to add water with both the wash and rinse cycles..
  • Washing Mach... Master
  • 5,323 Answers
Check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
By the way my advice is free cuz God is good!
new GE Hydrowave does not fill with enough water e - inlet testing washerwater inlet valve-n2one1aiwr4twi02ek2pnwzo-2-0_1.jpg
inlet dirty water inlet screen-n2one1aiwr4twi02ek2pnwzo-2-5_0new GE Hydrowave does not fill with enough water e - inlet how2clean inletvalvewest_washer4-n2one1aiwr4twi02ek2pnwzo-2-9.jpgds/images/inlet how2clean inletvalvewest_washer4-n2one1aiwr4twi02ek2pnwzo-2-9.jpg
Posted on Mar 24, 2017
4 Suggested Answers
  • 51 Answers
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Posted on Jan 23, 2008
  • 60 Answers
SOURCE: the washer only fills up full even when I put the load size on sm
Check the other knob or switch on top. Perhaps it has some settings regarding small, medium, or large load. This switch may be defective. Go to for more help on removal and replacement. You can also order a new one from them.
Posted on Mar 14, 2009
SOURCE: no agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Posted on Jan 21, 2010
GE Hydrowave top loading washer is leaking around the top side and back of unit when filling.
check for the water outlet from the water solenoid control valve
it may be displaced or broken and not directing water to the bowl
Sep 29, 2016 | GE GTWN4250MWS 27" Top-Load Washer, 3.7...
Top Loading Hydrowave. Washer fills but won't agitate. After a few minutes water is pumped out and it spins normally.
It almost sounds like the lid switch is working backwards but I have never seen that happen on a GE. The switch either works or goes bad. One other possibility is a defective water level switch. Thats also called a pressure switch sometimes.
Apr 17, 2015 | GE Washing Machines
Pressure line not filling
I am not a washer repairman. But I have repaired a few & had a run in with a similar problem some years ago. First off, the top of the line has to be vented, otherwise it will pressure lock as it start to fill, ( As your description indicates). I do not know where that vent is located but, you should be able to put a small amount of compressed air on the bottom of the line without damaging anything. The other possible that comes to mind, the samll plastic box at the bottom of the line, ( Assuming there is one on you unit), is, as I remember, a sealed unit. But is it possible that there is a partial obstruction, ( Lint, or whatever), inside there that is metering the flow? If so I would just buy a new unit, they can't be very expensive. Hope that helps. Let me know what you find please.
Mar 10, 2014 | GE WBSR3140DW Top Load Washer
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
My Ge Top load washer will not power up start button?,no lights.
Their is a fuse in the harness red wire that runs down from the control to the motor on the hydrowave washer. Hydrowave washer manual
Of course if yours isn't a hydrowave maybe you oughta post a model number. GE has several different styles.
Mar 09, 2013 | Washing Machines
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
Washer won't cycle past fill, keeps returning to fill cycle
That could be excess detergent causing the control to do extra washes to get rid of detected Suds. On these washers it is critical to use HE detergent and the right amount. Most often directions on detergent boxes are useless. This washer has a 3 phase motor with an inverter to change the current from 120 to 200 volts dc. If you continue to use wrong amounts of detergent the inline fuse will eventually blow from the motor overheating trying to correct overdose of detergent. Read more about it in the GE HYDROWAVE SERVICE MANUAL
Apr 24, 2010 | GE WHRE5260E Top Load Washer
We have a GE top load washer with the model number WDSR2120J. It new (almost 13 months old so the warranty has just expired.) When we turn it on, it won't stop filling up when it is full. Bubbles then come...
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling into the washer, then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. Also, the pressure supply tube connected to water level/pressure switch may have a hole in it or a bad connection, or possibly plugged up. This rubber tube must have an airtight seal at both ends to perform properly. be sure to check this item also. Happy to help, Tim.
Jul 01, 2009 | General Electric WDSR2120J Top Load Washer
No agitation in ge hydrowave rinse cycles
Dec 01, 2007 | Washing Machines
GE washer keeps filling with water.
It sounds like you have a bad fill valve assembly. Normally the valve opens and closes by an electrically activated solenoid which is usually controlled by a pressure switch. However...IF the diaphragm that closes on the valve is broken, has a hole in it, cannot close all the way due to an obstruction, or if your water pressure is too low, the valve will remain open and water will leak by. Since you didn't mention any problems with the hot water side of the valve, I would suspect that water pressure probably isn't a problem. Turn the water off and remove the hoses to the fill valve on the back of the washer. Inspect the cold water side for any obstructions and/or check for any damage to the valve itself. If you don't find anything obvious, replacing the fill valve will probably correct your problem. I hope this helps.
Sep 10, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
