If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine. What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not. need to know if it agitates or drains and just wont spin. if it agitates but no spin or drain, then you have a bad lid switch. if it wont agitate or spin, but will drain, then you have a broken drive coupling.
check the wig-wag.it is the part near the cam bar.has 2 coils on it. also check the yellow wire going to the solenoid it may look ok but could be broke internally.
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
