Question about Vehicle Parts & Accessories
How do I reset passlock on 2003 bravada
Just purchased used 2003 Oldsmobile bravada vehicle won't start after reset seats and mirrors
  • 80 Answers
Reset passlock, the passlock is built into the GM PCM, you can program the passlock with the GM Tech2 programmer at the dealer or if you put the wrong key in the car, leave the ign on for 20 minutes and it will go to bypass mode, you may have a faulty ign switch and the resistor wont read well anymore
Posted on Mar 02, 2014
Need to take back seat out of 2003 bravada dont have manual
push on the bottom seat and ull be able to acces the bolts for the back
Aug 21, 2013 | 2003 Oldsmobile Bravada
Bravada won't start when it's hot
Had a similiar problem with mine. Ignition control module will overheat and the vehicle will not be able to restart until the vehicle and ignition module cool back down. Ignition control module probably bad.
Jun 21, 2012 | 1996 Oldsmobile Bravada
My Oldsmobile 1999 bravada won't start, key is stuck in the ignition. It's not a smart key. The battery is good and it's not the starter. Is there a fusible link in this car, and if so, wh
Believe it or not, it is a smart key. passlock is standard on your vehicle. This link explains why it won't start.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jun 05, 2012 | 1999 Oldsmobile Bravada
Takes too long to switch from second to third gear (automatic) and the motor sound like it is running too fast. (2003 Oldsmobile Bravada)
clean carbon out of idle air control valve using non-chrolonated brake cleaner and a scraper.Then reset computer.Pull ECM fuse then put back.
Apr 19, 2011 | 2003 Oldsmobile Bravada
Well driving my 2003 oldsmobile alero a light came on the dash (security) what dose this mean
Will the vehicle restart if it is shut off? The security flashing light usually indicates a passlock issue with the key or the passlock.
Sep 20, 2010 | 2003 Oldsmobile Alero
We need to reset the computer on a 2003 Oldsmobile Alero
HI there if the scan tool you are using will not reprogram the theft module the try the 10 min relearn
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to start the engine, then release the key to ON (vehicle will not start).
  3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
  4. Turn OFF the ignition, and wait 5 seconds.
  5. The vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK. Important: The vehicle learns the Passlock™ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
  6. Start the engine. The vehicle has now learned the Passlock™ Sensor Data Code and/or password.
  7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles
Apr 10, 2009 | 2003 Oldsmobile Alero
2003 Oldsmobile Bravada interior power equipment not working
yes they do its sounds like a relay for the acc. side of the ing switch
Nov 27, 2008 | 2003 Oldsmobile Bravada
Vehicle Parts & Accessories Logo
110 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
