Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Connect mycloud to mac directly - Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Loading os please wait is stuck for already 6 days. No connection with the WD sentinel. What to do?
I had a similar problem with a "MyCloud". WD replaced it on warranty. The drive had failed. No data recovery.
Aug 12, 2015 | Western Digital Corporation Western...
Why can I not connect a MacBook Air with a WD MyCloud using a Nexxtech USB 2.0 Data Link Cable ?
The USB port of the My Cloud is designed to be used as an extension port. You may use it to attach another external to the My Cloud or device like a camera. If you prefer cable connection between your PC and your My Cloud, I would recommend you to use an Ethernet cable.
http://community.wd.com/t5/WD-My-Cloud/Connecting-My-Cloud-to-MacBook-Pro-directly-with-Ethernet/td-p/717882 - Check this similar topic in the official WD community.
Hope this helps
Sep 07, 2014 | Computers & Internet
Why does my nexxtech usb 2 0 data link cable not connect between a WD MyCloud and a MacBook Air
This cable you have is only for transferring data from one computer to another. To transfer data to this drive you must do so over the network or by loading your content onto a USB drive then connecting the USB drive up to the USB port on the WD MyCloud and using the MyCloud app to copy the data from the USB drive to the internal storage of the MyCloud drive. See the link below for more information. WD My Cloud Direct USB Transfer and SSH Access
Sep 07, 2014 | Apple MacBook Air
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Add music directly from mac?
If your Mac system has a MicroSD reader, you can add music directly from MAC to the MicroSD Card. You can also insert the MicroSD card into USB compatible phone connect the phone to your MAC and Load your Music to your MicroSD card.
Jun 01, 2010 | PNY 2GB microSD Memory Card
Just bought Mac with os x 10.6.1 and i want to bring my address book over from Outlook in Windows xp.
To move files by connecting your Mac directly to your PC:
  1. Connect your Mac to your PC using a standard Ethernet cable.
  2. Make sure that both computers are turned on.
  3. In the Finder on your Mac, choose Connect to Server from the Go menu to open the window.
  4. Type your PC's network address in the Server Address text box using one of these formats:
    • smb://DNSname/ShareName
    • smb://IPaddress/ShareName
  5. Click Connect.
  6. Follow the onscreen instructions to enter your PC's workgroup name, user name, password, and the volume or folder you wish to access.
  7. Your PC volume should appear on your Mac Desktop.
  8. Open the volume and drag and drop files directly from it to anywhere on your Mac.
  9. When finished, drag your PC volume to the Trash to unmount it.
Nov 03, 2009 | Apple Mac OS X 10.4 Tiger for Mac
Cannot connect to internet with a mac.
To use eathernet on a mac you would need to change you conecsion under system profernces. I hope this would help you.
Jan 04, 2009 | Zyxel P660HW-D1 Router
Can not get my cx6400 to print from my mac
You need a MAC driver disk or download.
If you don't have a disk, you can download the driver from the Epson site. I've added the direct links to the relevant downloads below, providing your Mac is connected to the internet.
These drivers are only for the Epson CX6400 on Macintosh operating systems.
If you are using version Mac OS 7.6 to 9.2, here's a direct link to the driver download: http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7Nsto14LFsNUjuRSXBZZOHy&tc=6
If you are using Mac OS X - Intel, here's the direct link: http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7M6qoJ6uYEojoMzz9oApk7e5aobGaUtdawU003D&tc=6
If you are using Mac OS X - PowerPC, here's the direct link: http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7Prg898nyvz3fMP+q1RgJB+&tc=6
Once you've downloaded the driver, it may be a ZIP file so unpack it where you can find it and double click the setup.exe file or program icon that unpacked.
This will install the drivers to your Mac computer.
You'll be asked to make sure the printer is plugged in and connected to the computer at some stage so that it can communicate with it and complete the installation.
Good luck
Nigel
The INK Store
http://www.the-inkstore.co.uk
Dec 11, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
15 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
