Question about NRS Brondell Swash 800 Bidet Elongated Seat S800EB
Sensor keeps beeping fluidmaster - NRS Brondell Swash 800 Bidet Elongated Seat S800EB
Fluidmaster
First shut water off at stop than flush all the water out of the tank next take a sponge and get all the water out of tank next unsrew the supply line from the valve under tank than move out of the way next unsrew the nut on the valve of fluidmaster than pull the fluidmaster out of tank stick the new fluidmaster in tighten nut srew the supply line back on turn on stop and let the tank fill up thats it if the fluidmaster dont shut off press the handle let some water out and adjust the fluidmaster screw Tip the water should stop a 1/4 inch below the flush valve tube in center of toilet
Jul 11, 2016 | Fluidmaster Plumbing
My fluidmaster 400 anti siphon for toilet will not stop filling making pump run over and over
Hi turtlerose07...
Sounds like you have one or two problems with the fluidmaster 400.
1...The float is set too high allowing the water to overflow into the overflow pipe and allowing your pump to run too much.
2...Flapper valve inside at the bottom of the tank is not sealing properly, thus allowing water to leak and causing the fluidmaster to keep trying to fill the tank with water and causing the pump to run too much.
Please take time to rate me
Aug 24, 2011 | Home
We replaced our 3 toilets with the Fluidmaster 400 and have had problems ever since. All the toilets are running water every 5 to 10 minutes and my water bill has doubled. What can we do?
Hello- If you replaced old ball and rod set with new fluidmasters they will most likely need to be adjusted, not all toilet tanks are of equal height. You will have to adjust water height,meaning you must keep water level below fill tube located in center of the toilet tank. Adjustment is done from bottom of the fluidmaster, they screw in and out to adjust height. You will notice threads along the bottom part of the fluid master, on the inside of the tank,they adjust up & down! Goodluck!
May 19, 2011 | Home
When flush my toilet, water keep running until i put my hand inside the middle and pull the float , then stop. toilet make is rapid sl
the ball **** fill valve is a poorly designed valve. replace it with a fluidmaster fill valve and a fluidmaster flapper. flappers do go bad after a year or ten depending on your water quality and choice of flapper but the fluidmaster fill valve will last a long time also. you can also get the water saver fill valve by fluidmaster and there is also a conversion set to change your toilet to a dual flush. all this is at lowes and there is a plumbing pro there to explain further. feel free to give me a positive rating. thanks!
Feb 15, 2011 | Home
Toilet does not stop filling, water keeps running
Replace your toilet fill valve with a fluidmaster 400A
Click here
http://411plumb.com/how-to-replace-your-toilet-fill-valve-with-a-fluidmaster-400a
heatman101
Jan 16, 2011 | Jacuzzi Home
I have fluidmaster in my mancesa toilet. After flushing the toilet tank doesn't refill unless I turn off the water supply and turn it back on. What do I do to fix this problem. Wayne
First thing to do is figure out if the problem is with the fluidmaster or with the shutoff valve. If the water doesn't run at all after flushing, then instead of cycling the shutoff valve, just loosen the nut where the supply tube attaches to the fluidmaster (under the tank). If the problem is in the fluidmaster, it will start to squirt out at you, otherwise it won't. Then you know what to disassemble and attempt to repair, or replace.
Jan 29, 2010 | Fluidmaster Plumbing
Toilet gasket fluidmaster 7500c instructions
Fluidmaster has an instructional PDF file that I found clear and concise. Find it here: http://www.fluidmaster.com/pdfs/7500_instructions.pdf
Hope this helps.
Oct 09, 2009 | Fluidmaster Plumbing
I have installed a fluidmaster 400 bottom inlet
I have installed 400A or 400LS valves on systems as low as 30psi, but below that I don't know that it would work very well if you needed it to fill faster.
Keep in mind that your pressure to the toilet will be 1/2psi for every foot above the fill level of the tank, which is reduced by friction loss in the pipe and fittings on the way to the toilet.
Sep 27, 2009 | Fluidmaster Plumbing
I have a 4112.016 American Standard Toilet and even with the floater all the way down the chain the water seems to keep running and going into the bowl.
1.The Flapper Valve isn't seating all the way, and allowing water to seep through. (At end of chain)
2.The Fluidmaster water control unit that is connected to the other end of the chain, isn't shutting off when the lever for it, is all the way in the down position.
Test the FluidMaster unit, by lightly applying pressure in a down motion, to that lever.
(Facing the toilet from the front, the FluidMaster water control unit is in the left corner of the tank. {Not trying to insult your intelligence}
The lever I speak of, is the small arm at the top of the FluidMaster. The Flapper Valve chain connects to this lever)
If it shuts off, you may have some fine sand, or other foreign material in the FluidMaster. [Taking one apart, and checking, then reassembling, is No fun!]
If it doesn't shut off when you apply pressure to that lever, you may have a bad diaphragm in the FluidMaster.
Suggest you replace this unit.
Aug 31, 2009 | American Standard 4112.016 Cadet Toilet...
NRS Brondell Swash 800 Bidet Elongated Seat S800EB Logo
63 people viewed this question
Top NRS Home Experts
Donni Steen
john h
Bill Boyd
Are you a NRS Home Expert? Answer questions, earn points and help others
