Question about Vehicle Parts & Accessories
Repair manuel rear struts - Vehicle Parts & Accessories
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Haynes manual 20 bucks
Posted on Oct 09, 2014
Mercedes 2000 s430 rear struts fail body siting on tires how to raise up manual
Not possible. The rear struts on this vehicle are air-assisted and require inflation to hold the vehicle up. If the air source has failed it will need repaired, If the struts themselves are leaking and won't hold up , they must be replaced. There is no other option.
Sep 12, 2016 | 2000 Mercedes-Benz S-Class
Rear passenger axle needs replaced
A Sunfire is front wheel drive, so there should not be a rear axle.
There is a rear strut, the hub and bearing is bolted to the trailing arm and strut. The tire and wheel bolt to the hub.
I would get two estimates for repairs before making a decision. It could have under-body damage too.
Jun 26, 2012 | 2001 Pontiac Sunfire
My wifes taurus right rear strut is leaking fluid also sway bar mounting rod had a bolt snap off how much do you thinks it would cost to repair.thankyou.
Labor rates vary by location and shop, so it's hard to give an exact estimate. I will say that (if they are more than two years old) you should replace both rear struts, and if the front struts are more than about four years old, you most likely should replace them too.
Parts cost for the struts are about $100-$200 each depending on model and such. labor should be about the same amount. So you are looking at $400-$800 for both rear struts or $800-1600 for all four.
Assuming the bolt is not hard to reach to drill out, it should not be more than $50 or so. If it is hard to reach, it could be more.
Sep 06, 2010 | Ford Taurus Cars & Trucks
Ihow do you replace rear struts on a 1999 ford
Suspension Strut: Service and Repair
Removal and Installation
REMOVAL
1. Remove the package tray trim panel.
2. Remove the upper strut and spring assembly nuts.
3. Raise and support the vehicle.
4. Slide the brake hose clip off and position the brake hose aside.
5. If equipped with anti-lock brakes, remove the Anti-Lock Brake System (ABS) sensor bracket bolt.
6. Remove the lower strut and spring assembly bolts and the strut and spring assembly.
INSTALLATION
1. To install, reverse the removal procedure.
Sep 11, 2009 | 1999 Ford Escort
Insturctions for replacing rear struts
raise rear of vechicle then support by jack stands.let rear suspension hang to take pressure off strut coil springs.remove rear package tray trim panel. remove rear wheel.remove brake load sensor .remove brake hose.remove stabilizer bar bracket and link.remove tension strut .remove spindle pinch bolt and strut assembly.if the strut coil spring broke you wont need a coil springcompressor.BESURE INSTALL NEW MOUNTING BOLTS AND PINCH BOLT.install the strut assembly.use a new pinch bolt .torque it to 50-67 ft lbs.torque the 3 upper mounting nuts to 19-25 ft lbs. tension strut torque nut to 35-46 ft lbs. stabilizer bar link torque to 60- 81 inch pounds.stabilizer bar bracket torque to 25-33 ft lbs.NOW INSTALL .brake hose / brake load sensor/ rear wheel /rear package tray trim panel.
May 31, 2009 | 2000 Mercury Sable
Shocks or struts?
I have 161,000 on my 00 Runner. Have had the shocks/struts changed TWICE.... (thats cause I have FUN with mine over the years) Personally, I would go with what the dealership says, then just replicate that at a good shop for cheaper price.
Mar 27, 2009 | 2000 Toyota 4Runner
Rear Strut
I hope this helps you
Feb 24, 2009 | 1993 Jaguar XJ6
2000 Buick LeSabre Struts
Yes there are struts on the front and shocks on the back. 2 of each. They are around $50-100 for the fronts. $30-100 for the rears depending if the car has air ride or not.
Jul 17, 2008 | 2000 Buick LeSabre
Vehicle Parts & Accessories Logo
12 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
