Question about HHB CDR850 CD Recorder
I need a web site for the HHB Compact disck recorder CDR 850
Need a website for information and repair
5 Suggested Answers
  • 112 Answers
SOURCE: about the HHB CDR 850 compact disc Recorder
You may need a new laser - it's a sony unit inside.
Posted on Dec 09, 2007
SOURCE: HHB 850 needs repair
You can contact HHB service team on 020 8962 5000. Or visit their web site and go to support and complete an equipment repair form and they'l get back to you. You can also email the engineers whose names are listed in the contact section. Web site is http://www.hhb.co.uk/hhb/uk/support. Hope it helps
Posted on Feb 05, 2009
  • 6 Answers
SOURCE: need owner's manual for HHB CDR-850 Where is
what is it you need? what is reoaur cebter? I have the machine and manual. My recorder died last night after 10 years. very disappointed!
Posted on Aug 31, 2010
  • 6771 Answers
SOURCE: HHB CDR 850-No laser lit up...shouldn;t there be light ie. laser
YesI when the unit is first turned on the laser will emit a red light when scaning, if no beam is present it is time to replace your player, not cost effective to repair.
Posted on Mar 06, 2012
Hhb cdr-882: what mean the letter "i/p"? (On the
That is the INPUT selector button for picking the inputs on the back. The manual for that unit is here: http://www.hhb.co.uk/hhb/global/brochures/CDR882%20User%20Guide%20v1.1.pdf
May 14, 2013 | Audio Players & Recorders
Mar 05, 2012 | HHB CDR850 CD Recorder
AFTER recording is made Tried to finalize and it says repair... what is causing this .
The CDR lost track of the information on the disc. This most often happens when the unit is powered off before the disc was ejected. Give the unit about 40 minutes to go through the disc contents and locate the tracks. When the Repair message goes away, then you can finalize the disc.
I hope this helps
Sep 24, 2010 | HHB BurnIt CDR830 CD Recorder
Need owner's manual for HHB CDR-850 Where is reoaur cebter?
Aug 07, 2010 | HHB CDR850 CD Recorder
Tengo problemas con el aire acondicionado esta tirando aire muy caliente aunque este en aire acondicionado.
Ok tienes que revisar si el compresor trabaja cuando activas el interruptor del aire si el compresor no se activa podria ser que le falte freon 134a al sitema,que tengas algun problema electrico.puedes comprobar el nivel de freon con un manometro si este esta bien tienes que revisar la parte electrica. Gracias
May 03, 2010 | 2002 Kia Sedona
Noise / Hum in recordings
hi, i once had the same problem with a kenwood cassette deck. it would play pre-recorded tapes perfectly but when it came to recording from another source i would get an annoying hum when playing back the recording, the fault turned out to be a faulty earth connection on the phono connectors on the rear, they were dry jointed and once resoldered the unit worked and the recordings were perfect. maybe you have the same problem? hope this helps?
Feb 14, 2009 | HHB CDR850 CD Recorder
Denon CDR-W1500 not recording
I had the exact problem and could not get any of the CR-Rs that I had to work. I looked up the code in the user's manual where it said the error means it's not a recordable audio CD and to refer to page 6. I looked at the front of the manual and saw that it mentions that the CD-Rs must be audio CD-R discs. I did some research online and found that there are in fact differences between CD-Rs that are just marked that and those marked as Audio or Music CD-Rs. I bought a set of CD-Rs that clearly had marked "Compact Disc Digital Audio Recordable" on the package. When I inserted this disc, I had no problems getting the recording to work. So, make sure the discs you use are clearly marked "Audio" or "Music". A computer burner won't know the difference, but your Denon recorder will.
Jan 27, 2009 | Denon CDR-W1500 2-Disc CD Recorder
Dec 26, 2008 | HHB CDR850 CD Recorder
HHB CDR-850 Professional loading problem
I had the same problem with mine. The manual says to unplug it from the power and plug back in. That did'nt seem to correct anything. I also was having an issue with recording. It would'nt record data for tracks and recording would scramble. I had this burner for 10 years and loved it untill last night when it crapped out on me completely. I am VERY disappointed!
Mar 30, 2008 | HHB CDR850 CD Recorder
About the HHB CDR 850 compact disc Recorder
Aug 14, 2007 | HHB CDR850 CD Recorder
HHB CDR850 CD Recorder Logo
53 people viewed this question
Top HHB Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
