Question about whipper snipper Garden
Shingu brushcutter - what is the fuel mixture
What is the fuel mixture ratio
  • 109 Answers
SOURCE: 2 stroke mixture ratio for strimmer
The basic fuel/oil mix is 50 to 1
Posted on May 06, 2009
SOURCE: 25cc trimmer gas ratio mixture
the correct ratio is 50-1 mix
Posted on Jul 01, 2009
pippall
  • 1486 Answers
SOURCE: petrol oil ratio mix
25%to!%
Posted on Aug 09, 2009
AUTODOC01
  • 216 Answers
SOURCE: gasoline mix ratio for Efco 8753 brushcutter
if you buy the small bottles of oil mix it with one gallon of gas easiest way .
Posted on Aug 25, 2009
  • 10865 Answers
SOURCE: whats the recommended 2-stroke fuel/oil ratio for
50:1 is the ratio. the easiest way to do this is to get a small bottle of the 2 stroke oil premeasured for one gallon of gas.
Posted on Feb 25, 2010
Testimonial: "thanx"
What is the code 171 mean on my dodge ram 1500
P0171 Chrysler - Fuel System Lean
Possible causes
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection
Tech notes
If the P0171 is combined with the P0174 code, it's very likely that the problem is caused by an intake leak. If there are no intake leaks, the next step is to replaced the air filter and clean the air flow meter. If the problem persist the front oxygen (O2) sensor may need to be replaced.
When is the code detected?
- Fuel injection system does not operate properly.
- The amount of mixture ratio compensation is too small. (The mixture ratio is too lean.)
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel Consumption
P0171 Chrysler Description
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the Malfunction Indicator Light (MIL) (2 trip detection logic).
P0171 Chrysler Fuel System 1 1 Lean
Sep 04, 2014 | Cars & Trucks
What is code p017.2 for a 2002 dodge caravan
This is the closest I've come to the code you are looking for. I searched all Dodge codes and didn't see any with a "point 2" but I found code P0172. According to EngineCodes.com your fuel mixture is probably too rich. This is what the site had to say:
Possible Causes for this Code:
- Exhaust gas leaks
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35waCcFhN
This code is detected when:
- The amount of mixture ratio compensation is too large. (The mixture ratio is too rich.)
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35waXE700
Possible symptoms:
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35waruoIU
P0172 Dodge Code Description:
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the MIL (2 trip detection logic).
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35wbfFdyj
Hope this helps!
Jun 27, 2014 | 1999 Dodge Grand Caravan
Clutch housing on mcculloch elite 3325
Unknown. I recommend contacting your local service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Apr 08, 2013 | McCulloch String Trimmers / Brushcutters...
Part number for McCulloch trimmer 1385L primer bulb
Refer to your service manual.
Contact us
User manuals
McCulloch Service
Oct 24, 2012 | McCulloch String Trimmers / Brushcutters...
Down to the final OB code on my truck...Po174
P0174 FORD - Fuel Injection System Too lean Bank 2xicon.jpghttp://engine-codes.com/p0174_ford.htmlForum CodePossible causes- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes The codes is usually set when there is an intake leak after the air flow meter, before replacing any parts check for loose or broken hoses and intake gasket leak. On Ford some models dirty air filter, and dirty or faulty air flow sensor are the cause of the problem.
It's a very common problem for the Ford Windstar. Here a link to a web site with information how to repair:
When is the code detected?- Fuel injection system does not operate properly.
- The amount of mixture ratio compensation is too small. (The mixture ratio is too lean.) Symptoms- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel ConsumptionP0174 FORD Description The Powertrain Control Module (PCM) monitors the engine Air/Fuel mixture ratio, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The PCM calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the PCM judges the condition as the fuel injection system malfunction and light up the engine light.
Oct 08, 2012 | Cars & Trucks
Code 0171
Here is the definition.
Causes could be a faulty O2 sensor or a fuel problem.
P0171 CHRYSLER Description With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
Read more: http://engine-codes.com/p0171_chrysler.html#ixzz24c6wxqAd
Aug 25, 2012 | Chrysler Town & Country Cars & Trucks
Gas/oil ratio for a Jonsered LR 300 brushcutter
Clean fuel and a good quaility two stroke oil mixed at 50.1
Apr 19, 2012 | Garden
I have a code reader and the code is P0171 P0174 System too lean. what makes the system too lean?
P0171 - Fuel Injection System Too Lean Bank 1
Possible Causes:
- Intake air leaks
- Front Heated oxygen sensor may be faulty
- Injectors may be faulty
- Exhaust gas leaks
- Lack of fuel
- Mass air flow sensor may be faulty
- Incorrect PCV hose connection
P0174 - Fuel Injection System Too Lean Bank 2
Possible Causes:
- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
What Causes These Codes: Fuel injection system does not operate properly. The amount of mixture ratio compensation is too large. (The mixture ratio is too rich.) The Powertrain Control Module (PCM) monitors the engine Air/Fuel mixture ratio, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The PCM calculates the necessary compensation to correct the offset between the actual and the theoretical ratios. In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the PCM judges the condition as the fuel injection system malfunction and light up the engine light. The codes is usually set when there is an intake leak after the air flow meter, before replacing any parts check for loose or broken hoses and intake gasket leak. On Ford some models dirty air filter, and dirty or faulty air flow sensor are the cause of the problem.
Jan 16, 2011 | 2000 Ford Explorer
Whats the recommended 2-stroke fuel/oil ratio for echo brushcutters?
Feb 25, 2010 | Echo Rapid Loader, Trimmer Head
Garden Logo
250 people viewed this question
Top whipper snipper Garden Experts
John Mayer
John Mayer
Level 1 Expert
richie46
ray gallant
Are you a whipper snipper Garden Expert? Answer questions, earn points and help others
