Question about Microwave Ovens
Microwave went 'poof' and then stopped working
Put a cup of tea in the microwave, pressed the button, system ran for 2 seconds, a "poof" kind of sound, and then it shut off
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Ge microwave oven - JVM1653SH shuts off
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may send you a replacement magnetron. GE Customer Service is here.
Posted on Nov 21, 2008
ginko
  • 19396 Answers
SOURCE: i lost instructions to genius
Hi.
Please click here to open the Panasonic support page containing both manuals for the manual listed in question.
Regards.
Ginko.
Posted on Nov 10, 2010
  • 8909 Answers
SOURCE: Door is stuck and will not open. Tea was heated
Door catches.
One of the latches may have broken off or got stuck and is not lifting the dother latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Posted on Dec 30, 2010
SOURCE: burnt smell in microwave
Hi Diane, that happened to me last year my daughter burned popcorn in microwave. I washed it out with baking soda and water, hot water. Then rinse it out good and place about a tsp. of baking soda in a small bowel with a little water set timer for 10 seconds on high power, this helps to nuetrilize the air flow and now you can use it with out any burn smell.
Posted on Feb 22, 2012
Door will not open
Put right hand on lower section of the door to the right, "crevice" with the left hand press the button to open the door at the same time pull gently to moderate this will release the door in some cases, even if this works you will need someone to check it out.
Apr 04, 2012 | Microwave Ovens
Microwave shut off completely
Microwaves have an inline fuse inside that fatigues over time.Take the cover off,follow the power cord after it enters the housing to locate the fuse.
Mar 14, 2012 | Amana MVH220W Microwave Oven
Burnt smell in microwave
Feb 22, 2012 | GE Microwave Ovens
I have owned a AMC5101AAW for about three and a half years. It has been a good microwave,perfect for my needs. The display went black and the buttons didn't work right after I boiled a cup of water for...
It sounds like it could be just a bad crimp connector supplying power to the whole system, which would have to be the fuse holder on the mains input panel.
Worth a look!
Jan 01, 2011 | Amana AMC5101AAS Stainless Steel 1000...
Was microwaving a hotdog on a paper plate covered by another paper plate and the microwave just kind of went poof and now nothing lites up (display) and it wont work. I checked the breaker it is on and...
Yes there is.
Unplug the MW.
Uninstall from wall mount (if installed that way.).
Remove outer cover by removing the screws at back and (possibly) bottom sides.
Locate fuse. Replace only with an equivalent type and amperage.
You can test the MW without reinstalling or putting the outer covering back on.
Dec 21, 2009 | Kenmore 63672 Convection/Microwave Oven
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Whenever I went to warm up my tea this morning, my microwave says, "LOCKED" regardless of which button I push. I can't get it to work no matter what single button I push or combination of buttons. HELP
It sounds like you may have accidentally set the child safety lock. Some ovens have this feature as a safety device to prevent children from manipulating the controls. If the model number you have this listed under is correct, all you have to do is press and hold the ENTER/START button for 4 seconds and the lock will clear. If the model number is not correct, post back with your correct information, or refer to your owner's manual under the "Operating Instructions" section.
If you have questions, or require additional assistance, please let me know. I hope you findthis helpful.
Aug 21, 2009 | Maytag MMV4205 Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
10 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
