Question about Samsung WF337AA Front Load Washer
Samsung wf218 no power to drain pump - Samsung WF337AA Front Load Washer
4 Suggested Answers
  • 6 Answers
SOURCE: samsung model WF218...not draining
Just follow the few steps here as follows. First switch off and unplug the mains. Now you look for the screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water in the tub bottom. Examine your pump also, clean out the impeller. Carefully refit all. For some front loader models after removing the bottom toe panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment. Check the exit hose of the washer for blocks.
The machine will always leave about 3 cup fulls of water in the bottom but usually you cant see it inside the metal drum.It's possible that the pump is restricted & not flowing out properly,there is a button trap,a little flap door at the lower front of the machine that should be opened & cleaned regularly.
Now your machine will be in good maintained condition. Hope this would have helped you.
Posted on Jul 22, 2010
washdryman
  • 154 Answers
SOURCE: HOW TO REPLACE DRAIN PUMP
PUMP CAN BE ACCESSED FROM THE BACK OF THE MACHINE
Posted on Nov 08, 2010
  • 6277 Answers
SOURCE: samsung wf218 washer will not
Try all of this first!
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 01, 2011
Samsung front washer WF203ANW will not drain.
Have you tested for power to the pump when in drain cycle? Could be relay or wiring issue
Jan 21, 2018 | Samsung Washing Machines
My Samsung Model#WA5451ANW/XAA washer keeps repeating the rinse and spin cycle over and over and my clothes are still wet because spin cycle is not spinning clothes fast enough.
From the information you have supplied, I suspect that the machine is not draining the water away,
1] Check that the drain pump is working (it would be easier to hear it running, before the machine starts the spin cycle, or if your machine has a "drain down" feature)
2] If the pump is running, stop the machine and unplug it from the mains power. Remove the machine drain tube from the point where it is plumbed into the household waste pipe, and lay it down into a bucket, or large pan and allow the water to drain down [ you should expect to get up to 2 gallons (10 Litres) of water from the machine]
Allow the water to drain down completely by holding the drain hose as low as possible into the bucket.
3] once the water has drained completely, remove the drain hose from the pump and check that the drain hose is not blocked.
4] If the hose was clear, and the pump was running (in tests [1] & [2] ), it will be necessary to check that the drain pump, and the main hose from the tub to the pump are clear of obstructions.
Remove any foreign objects, and re-assemble the hoses to the pump to the machine, and the drain hose to the domestic plumbing.
Plug the machine into the mains power, and and set the machine to run on the "last rinse" and "spin" cycles and test to see if the problem has been rectified.
I hope this helps cure your problem.
Oct 13, 2016 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
I have a Samsung 8kg top loader and had to change the drain pump. The new pump just runs constantly while the power is on.
The old drain pump has taken the control board out with it & it's now stuck in the drain pump cycle. You will need to replace the main pcb to fix this one.
Jun 15, 2015 | Samsung Washing Machines
How do I over ride power button, force shut down
The dishwasher has detected a leak, and is trying to drain all the water out of the dishwasher. The problem is that the water has leaked into the base of the dishwasher, and the drain pump doesn't drain water from there! You dishwasher probably has a 1 or 2 lights on (or flashing), which also, when decoded, would indicate a leak. Basically, you have to pull the dishwasher out and sop up and dry up all the water in the base. That will stop the drain pump from running, but you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose. Good luck! If this sounds like more work that you feel qualified to do, I recommend you call a professional repairman. For Samsung dishwashers, I recommend calling Sears.
Aug 26, 2014 | Samsung DW80F600 24" Black Built-In...
Samsung washing machine water seems to be coming out of the dainage point under the base
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Thank You for using fixya
Apr 10, 2013 | Samsung Washing Machines
Samsung wf218 washer will not drain. already cleaned drain and placed in spin cycle to see if it will drain. Did not work. how do you get pump out. is it thru front panel or back. do you have a...
John C
Jul 01, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
My samsung machine has check filter message every after a wash
Ensure that the drain hose is not kinked and the debris filter is clear, switch off the power/reconnect, the drain pump should operate to drain W/M
May 03, 2011 | Samsung SW62ASP Top Load Washer
HOW TO REPLACE DRAIN PUMP IN WF218
Nov 08, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
Samsung model WF218...not draining
Jul 22, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
Samsung WF337AA Front Load Washer Logo
12 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
