Question about Brother MFC-8460N Laser Printer
When printing my Brother 9970 CDW is making a grumbling sound....It sounds like the paper feeder is having a hard time grabbing the paper . Is this a usual thing?
The noise is a grumble with a clicking noise.
BondoFox
  • 40 Answers
SOURCE: Brother MFC - 7420: Paper will not feed!
Does it make the same sound if you feed the single sheet through the bypass with the paper drawer removed? I hate to say it, but your printer's paper feed mechanism may need replaced. Go to http://www.brother-usa.com/AskUs/default.aspx and ask Brother to diagnose this one; I think they'll confer with me and should be able to point you to a nearby Brother-authorized repair center. Let me know what happens!
Posted on May 29, 2007
SOURCE: Brother HL-5250dnt - Clicking Noise and not picking up paper
You may have to use a true Brother toner cartridge as I have the same problem with me MFC 8500. If I use a compatible cartridge it clicks and if I use a geniune Brothr cartridge it does. Brother direct brought this to my attention.
Posted on May 30, 2009
komguy
  • 2306 Answers
SOURCE: clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Posted on Jun 24, 2009
SOURCE: keeps saying no paper Makes loud clicking noise
The clicking sounds seems to be made by the small gears on the side of the tray. When you move the gears, it should push a plate beneath the paper upwards, and the paper with it, allowing the paper to be feed.
I'm not sure what I did to fix it. I removed the paper and cleaned both feeding rectangles (to the front of the tray -- nearest you). One is underneath the paper and the other is in the front, center.
I then made sure that, when I move the biggest gear (the one that isn't round) that the paper moves upwards.
Posted on Sep 01, 2009
SOURCE: My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Posted on Mar 11, 2010
How do I check ink levels on BROTHER MFC-9970 CDW PRINTER
Start > Programs and Brother Control Center
Click device setings,
Click on the icon that says ink level.
Jul 20, 2016 | Brother MFC Office Equipment & Supplies
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
PAPER FEED DOESNT WORK KONICA MINOLTA COLOR PRINTER
This happened to me one time after I pulled out a jammed paper the wrong way. I pulled it from the paper tray. Heard the sounds, it tried to grab the paper, but couldn't. It happened a long time ago, so I'm fuzzy on which part I tinkered with...but I recall that because I pulled the paper (backwards) from the tray, it flipped a lever/feeder/roller/thing and that 's why it wasn't grabbing the paper. If you look in the paper tray as the rollers go down to grab the paper, you'll see what's not working......sorry, lame solution.
Mar 26, 2009 | Konica Minolta magicolor 2430 DL Laser...
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
Printing to memorex cd lable paper
the paper feeder cant grip the back side of the paper. It slip through the feeder and the positioning led control cant adjust the correct positioning for printing!
Try another brand of paper!
Jan 18, 2008 | Brother MultiFunction Center MFC-440CN...
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
May 07, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8460N Laser Printer Logo
42 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
