Question about Weil-McLain Ultra 155 Ultra Series 3-UE High Efficiency Modulating
Weil mclain ultra boiler not working
Boiler not firing up and heating
I have a mclain 68 boiler... I have no power going from boiler to thermostat. what can that be?
Could be a disconnected wire or failure of the thermostat power supply.
Oct 23, 2016 | Heating & Cooling
Boiler working but no hot water
Pump circulating heated water to the tank? Set the temp adjustment on the tank?
Sep 02, 2014 | Weil-McLain Ultra Plus 40 Indirect Fired...
Set up for heating and lighting pilot
When is the last time you had it serviced By a Tech?
Oct 24, 2013 | Weil-McLain CGa-25-SPDN, NG, Gas Fired...
Have a water leak inside boiler keeps putting pilot light out
Not good at all. Check for a fill level probe/float/sensor that may be acting up causing the unit to over fill, or you may be looking at buying a new boiler.
Feb 18, 2013 | Weil-McLain CGa-25-SPDN, NG, Gas Fired...
LOW WATER CUTOFF IS CHATTERING ON WEIL MCLAIN BOILER MODEL EVH95. WHEN THE CUTOFF IS TAKEN OUT OF THE CIRCUIT THE BOILER FIRES, BUT WHEN IT IS PUT BACK, IT WILL NOT STAY LIT?
Don't jumper that control out. You likely have some thing going on with the make up water. best i can do with information provided. T
Jun 16, 2009 | Heating & Cooling
Weil-McLain Ultra 155 Ultra Series 3-UE High Efficiency Modulating Logo
365 people viewed this question
Top Weil-McLain Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Weil-McLain Hardware and Accessory Expert? Answer questions, earn points and help others
