Question about InFocus ScreenPlay 4800 Multimedia Projector
How to tell if your bulb is broken
We just got a new bulb, we plugged it in and it doesn't work. How can we tell if the bulb is defective?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Put the new lamp into another projector ,you can check the lamp whether if is OK
Posted on Feb 10, 2014
1999 honda accord coupe ex Trunk light doesn't work
If you have 12V at the WHT/BLU connection to the trunk light, operating the trunk latch causes a switch to close and connect the other lead to ground. If you jump the ORG lead directly to ground, the trunk light should come on and verify the latch switch is defective. It also is possible the trunk light socket is defective
Oct 18, 2012 | Cars & Trucks
Washer will not spin dry
see the causes:
t doesn't pump or spin
frozen pulley or broken belt replace+lid switch open or defective replace
It pumps, but doesn't spin
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, the basket is worn.
It spins only with the lid closed
for safety, only sping with the lid closed.
Jun 19, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine will not spin
see this causes:
It doesn't pump or spin
frozen pulley pump, or broken belt replace+lid swtich defective
lid switch defective,motor coupler defective,+belt broke, clutch worn, +drive motor defective, +transmission is not shifting properly+basket drive worn replace. see the diagram
safety reasin the spin working with the lid closed
see the diagram .God bless you
Jun 19, 2012 | Fisher and Paykel Washing Machines
Zanussi fj12544 fills but won't wash
see this probably cause:
frozen pulley or broken belt, replace
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
It doesn't power on
Your camera can be defected. If you buy new batteries, and it still doesn't work, than you'll probably want to send it back to the manufacturer. First, call them and tell them your problem, and if that doesn't work, than you might want to carefully examine your camera, to check if everything is in the correct place, and their all working correctly.
Jun 11, 2012 | Canon PowerShot A560 Digital Camera
Mazda cx7. both high beams work and one low beam works. how can i tell if its a headlight or some other problem
Thanks for choosing FixYa and welcome. These new lights have two types lin one bulb, one for the low beam and one for the high beam. Find the bulb that isn't lighting for the low beam and replace it with a new bulb. If it doesn't work, you need to check the wiring to that specific light. Since it is only one, the new bulb should work.
Oct 01, 2011 | 2000 Mazda MPV
On my `06 Dodge Ram 1500 my left LOW beam doesn`t work ALL other lights work fine. Only low beam on drivers side. I tried 3 new bulbs,didn`t help.
You probably have a bad plug or a broken wire on the low beam of the left side. I would replace the plug for the bulb and run a wire from the low beam on the right side or , locate and bypass the bad section of wire going to the current plug if the plug is still good.
Nov 05, 2010 | 2001 Dodge Stratus
The boot light will not work even with a new bulb
Fast solution:
Assuming all fuses are OK.
Check the filaments (look for a broken filament wire) in the old bulb to make sure it's a bulb problem. If the old bulb is truely defective, check the new bulb to make sure it does not have a broken filament. If the bulb looks OK, take a look at the socket to make sure that it is not rusty or corroded. If the socket contacts are not clean, take a small piece of fine sandpaper and clean both the center contact and the inside of the socket.
If you have tried these things, and the light still does not come on, you'll have to do a continuity trace of the wiring to fine where the power to the bulb is being interrupted.
Jul 13, 2009 | 2004 Ford Fusion
Cooktop bulb broke off inside receptical. Removed all, no work.
Try another bulb. Sometimes even new bulbs are defective.
Mar 20, 2009 | Whirlpool MH7130XE Microwave Oven
InFocus ScreenPlay 4800 Multimedia Projector Logo
37 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
