Question about OKI B4600 Printer
Oki b4600 says no paper in tray 1. Where is the tray located.
The printer says the letter tray number 1 is empty add paper. I cannot find the tray , there is paper in the bottom tray. I have turned the printer off and back on, removed and replaced the paper nothing is working please help
Buschchris1
  • 474 Answers
SOURCE: OKI B4600 Printer will not print = error - paused
Does it have a control panel or buttons on the printer itself?
If so, are any of them blinking or red?
Sometimes an error will cause a pause in the printer and you have to press one of the buttons to get it to start back up again.
http://my.okidata.com/PP-B4600-Black.nsf?opendatabase
This is the link to the manuf. website. I did a search on your model, theres a few so i guessed. but the manuals are available along with drivers.
I suggest you go and update them and go through the PDF and see if there is anything partaining to this issue.
I went through the PDF a bit and didnt see anything partaining to the PAUSE issue but try going through and see if anything is it.
On the printer icon on the bottom right of your task bar, right click on the printer icon and see if you can select CANCEL print job, then try unpausing it. Also, power off and then power back on and see if that clears it.
You may have to un-install the printer and re-install it and update the drivers to clear it.
Sometimes a Print job will get stuck in que when theres a jam or something and it wont continue till the issue is resolved, then you open and close the top cover and that resets it, it rechecks then continues.
Good luck.
Posted on Feb 04, 2009
SOURCE: oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Posted on Jul 09, 2009
KudesNIK
  • 22 Answers
SOURCE: Oki error 380
Open the righthandside cover and check for remaining paper there!
Posted on Jul 24, 2009
SOURCE: How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Posted on Oct 07, 2009
Testimonial: "The one and only answer!!!!"
  • 21 Answers
SOURCE: oki b6200 paper jam
restart the printer or reinstall driver again.
Posted on Oct 08, 2009
One of my employees use an Oki B4600. When she tries to print, it kicks the main tray out. This results in paper not being able to feed then it says paper jam (even though there is not an actual jam). Any...
Try to clean every rubber roller in the printer. Make some soft "paper" wet with vinniger (Juuice from grapes (not to drink but for in salad's)) and rub it over the rollers. So they can transport paper better.
If possible, removing the rollers, and then cleaning.
Ralf.
Dec 03, 2013 | OKI B4600 Printer
Tray 1 doesn't feed while tray 2 has paper, after I empty the paper from tray 2, tray 1 work fine.
if you setup tray 1 any type, any size and tray 2 to plain, and letter size, it will allow you to use tray 2 for your plain letter jobs but will pull from the manual feed tray first only if the paper is in the manual feed tray if this makes any sense to you... please mark this as a fixya...
Nov 24, 2013 | HP LaserJet P4015N Printer
My paper feeds out the back and I want it to print out the front. How can I set this up?
If the paper output tray is pulled out at the bak then paper will exit through the back (face up). If you push this tray down then paper will exit out the top and lie face down on top of the printer. The tray that pulls out of the front of the printer is a input tray only and cannot be used to output any pages.
Jul 28, 2011 | OKI Electric Industry B4600 Laser Printer
PAPER FEEDS OUT OF THE BACK INSTEAD OF THE FRONT
If the paper output tray is pulled out at the back then paper will exit through the back (face up). If you push this tray down then paper will exit out the top and lie face down on top of the printer. The tray that pulls out of the front of the printer is a input tray only and cannot be used to output any pages.
Jul 26, 2011 | OKI Electric Industry B4600 Laser Printer
Paper jam
this is not a good printer.remove the paper tray and open the top cover.Remove the drum cartridge and remove any paper. you may also pull down the tray in the front of the printer and look for paper in there.
Dec 17, 2010 | OKI B4600 Printer
I have an Oki b4600. Any time I try and print It fails and says check paper tray. What can this mean?
It means check the papar tray ...
Do you have paper in the tray?
Do you have the right SIZE paper in the tray?
Is it inserted into the tray correctly? and is it all the way in?
Is there a jam in the paper tray?
Is the tray in the printer correctly? Is there a cover on the tray and it is in the proper position?
Thank you for your question. I hope my response is helpful to you. If it is helpful, the courtesy of a response and positive vote will be appreciated. Thank you.
Aug 16, 2010 | OKI B4600 Printer
Paper not pulling from tray 2 when tray 1 empties - Lexmark T654
For the majority of the Lexmark printers, all that needs to be done is to set the paper size and type the same for each drawer. Example - drawer 1 & 2 sizes are set to letter, drawer 1 & 2 paper types are set to plain. Set up this way, when drawer 1 empties, the printer will automatically switch to drawer 2 to supply the paper.
May 20, 2010 | Lexmark Office Equipment & Supplies
How do I have printer switch from empty paper tray 1 to the full 550 paper tray 2
Make sure the paper type and size in both trays are the same. If you are using letter size for both trays, make sure the settings in tray 1 and 2 are the same. If the settings are the same and it still fails to grab from the full tray change the engine settings in diag mode. Hope this helps but if you need more assistance, leave a comment and I'll get back to it. Thanks.
May 10, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN PAPER, USE PLAIN EXEC INSTEAD? THE PRINTER IS LOADED WITH 8 1/2 X 11 LETTER SIZE PAPER.
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
Feb 11, 2010 | HP LaserJet 4050 Printer
Oct 07, 2009 | OKI B4600 Digital Mono Printer - Black
OKI B4600 Printer Logo
533 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
