Question about John Deere 2012 7200R 24230
John deere troubleshooting
My JD 7200 diesel tractor just shuts off randomly. I replaced the fuel transfer pump and filters, but it is still doing it. And it is like the tractor just shuts off. No hesitating or sputtering.
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
nova2nv
  • 197 Answers
SOURCE: john deere tractor x585 not getting 12 volts at fuel pump
To check pump u remove fender deck,unhook connector, put 12 volt power to it.I have seen pumps react to a swift kick to the fuel tank,NO JOKE.You first have to check fuses,2 on control board and early x585 machines had a single red wire near control board that was only for fuel pump.Remove right side air screen and check for voltage on the relay closest to the radiator.Red wires #231/232 feed your fuel pump relay.Current flows from that relay #655 pink wire and goes to your fuel pump .Also check#215 grey wire {fuseable link}coming from starter post,they WILL burn out,it goes to #221 red wire with inline fuse and feeds rear of the 2 relays,that is your EFI relay.You have 3 fuseable links coming off starter post,check all of them.
Posted on Jan 01, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
Diesel filter changed, when driving along it will splutter and chokes off as if not getting fuel. can you help please.
Make and model May have air in the system. Most have a bleed screw on top of filter housing. Let the filter fill, then close
May 21, 2015 | Diesel Garden
How do I change the fuel filter on my 3020 John Deere diesel tractor
Leaving the fuel valve on the tank in the on position will allow fuel to run through the line & keep the air purged during removal. On the other side between the pump & the filter, having the new filter topped off & speedily installed will lessen the chance of air entering the line. Once the filter is installed, open the bleed screw at the top of the filter. Just my redneck way.
Oct 05, 2014 | John Deere Ar50041 Diesel Fuel Filter 3020...
Out of Diesel
This particular JD engine has an individual fuel pump for each cylinder. The injectors, fuel lines, and pumps are not accessible from outside of the engine. There is a hand primer pump built into the top of the fuel filter. Start by removing the rubber outlet line from the filter base and pump the primer pump until fuel come out of the filter base outlet. Ounce fuel comes out of filter reconnect the line and continue pumping by hand until the pump button feels solid, then crank engine until it starts. This works better if a helper is available to operate the starter while continuing to pump the hand primer. This is normally all that is needed after running out of fuel.
If fuel does not come out of fuel filter base there may foreign material inside of primer pump. Primer pump can be disassembled and cleaned. If fuel comes out of filter, primer pump become feels solid but engine does not start the fuel control rack inside of engine may be sticking in the off position. This may sometimes be overcome by clicking the key switch from off to on rapidly. If not you may have to have your dealer remove the governor cover to free the rack.
Mar 19, 2014 | John Deere 4020 Gas & Diesel Tractor...
John deere 415 diesel fuel flow
If its a diesel, the fuel pump where the steel lines come down from top engine. Follow fuel line coming coming from tank to find filters.
Jan 16, 2014 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Occasionaly the engine shuts off and won't start on JD gx345.
If the fuel pump is working correctly then the problem is between the tank and the pump. run a fuel line from the pump to a gas can. If the pump is working it will siphon the fuel into your filter. If the pump is fine then there is blockage, broken fuel line (sucking air), or something blocking the pick up inside the tank.
May 23, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 2012 7200R 24230 Logo
Top John Deere Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a John Deere Building Material Expert? Answer questions, earn points and help others
