Question about GoVideo Go Video DVD/VCR Combo
Manually disable remote lock - GoVideo Go Video DVD/VCR Combo
Can I disable OR remove the anti-theft device?
Do you have the remote keyless fob? Old contacts can cause this...replace the keyless fob...parts stores about $15....be sure to clean the circuit board on the chip...you will use this in the new shell that comes with new touch buttons...
Sep 30, 2015 | 2005 Buick Century
Disable factory alarm
You are not able to disarm the factory alarm on this vehicle. You will need to have it diagnosed. But the issues sounds to me like the key fob is bad and needs to be replaced
May 19, 2014 | 2007 Kia Spectra LX Sedan
We have no remote for tv, the child lock has been set manually and it has disabled the volume and channel control
On the side of your tv press the MENU Button to display TV Channel. Press the P+/P- buttons to select the CHILD LOCK OPTION. Press the VOL+/VOL- buttons to enable or disable the function. ON means it is locked OFF means function key is active.
COPY & PASTE THIS LINK INTO A NEW BROWSER AND CLICK SAVE. This should bring up your user manual for this specific TV. Good luck.
http://www.google.com/url?sa=t&source=web&cd=4&ved=0CDsQFjAD&url=http%3A%2F%2F86.89.130.62%2Fcache%2Fdocument.php%3Fdata%3D79643CB3-508D-5B6A-8586-160F02C5E75A%26file%3DGTVL20W7HD.pdf%26archive%3Ddoc00010&rct=j&q=goodmans%20gtvl20w7hd%20child%20lock&ei=FvN3TfKRCITXrAHFqoXQCQ&usg=AFQjCNEQJIgfu81RtZzD_Qum0XeSXcrlgA&sig2=RTLdIG-mbWg-0URhTIN97Q
Mar 09, 2011 | Televison & Video
If I unlock car with key, horn blows. If I start vehicle, it starts okay but shuts off immediately afterward. I tried unlocking manually, then relocking manually. Batteries are NEW in remote and Reily's...
did you try doing that with other door?if not i would try then unlock doors then if horn don't blow put key in and cycle 3 times then turn off wait a few then start you may also find a reset procedure in the owner manual hope this works 4U if it dos please share it with us thank you
Mar 12, 2010 | Dodge Durango Cars & Trucks
REMOTE KEY LOCK DOES NOT WORK BATTERYS NEW BUT ALARM WILL NOT SHUT OFF WHEN FIRST START .HOW CAN I DISABLE ALARM
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Carry out the following within 1 minute: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction.
How
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Remote controls can also be programmed using diagnostic equipment.
NOTE: A maximum of 4 keys can be programmed
Feb 09, 2010 | 2000 Volkswagen Beetle
98 Jeep how do you disengage alarm. Only have one remote
there is no way to do that being that the factory alarm is controled by the BCM (body control module) your only option is to go to the dealer and buy two new remotes and have them set to the frequency of your vehicle.
Sep 09, 2009 | 1998 Jeep Grand Cherokee
1994 jeep grand cherokee
There is a security feature that will allow to go for a short distance but will stop. It is basically the same as the alarm, when you lock your doors, and then shut the door as you exit, there is a red security light that will blink in the dash. If you manually unlock and open any other door besides the driver door, the alarm will go off. To disable the alarm you have to cycle the key in the driver door. The same goes for the security feature. Cycling the key in the driver door lock manually, should disable the security feature until the doors are locked again. There may be a problem with the remote if you use it instead of you key to unlock your door.
May 06, 2009 | 1994 Jeep Grand Cherokee
Remote keys wont open vehicle
You can try calling a locksmith and see if they can get in. Locksmiths can use a tool to open the door by catching the rod inside the door frame. The last time I used a lock smith to open a door, it ran about $35.
I suspect once the battery issue has been resolved, you will need to reprogram the key fobs or figure out how to disable the alarm.
Mar 31, 2009 | 2005 Jeep Grand Cherokee
GoVideo Go Video DVD/VCR Combo Logo
15 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
