Question about Bissell 9200 Upright Vacuum
Proheat repair diagram
Neighbor took it apart and now doesn't spray enough water and flow control does not spin at all
  • 25 Answers
SOURCE: My Bissell 9500 Proheat 2X has no suction.
I think you have a suction problem, as everyone else seems to have! Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use). There is a little red plastic piece about 1 inch square on the under side of it. Flip open the little door on it and you will probably find that it is blocked with hair, carpet fibre, etc.. Clean it out and your problem will hopefully be solved!
Posted on Sep 18, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
  • 10 Answers
SOURCE: my carpet cleaner will not spray. Maybe a little thru the tool but not enough pressure to SPRAY
p.s. Make sure you do give it about a minute after you turn it on before you try spraying. If the pump is not allowed sufficient time to prime, you may not get proper flow.
VacuumRepair
  • 438 Answers
SOURCE: Bissell Proheat 1699-5 won't spray, belt ok
Hi There,
It sounds like to me that this may be your pump. The newer ProHeat 2X models actually have a Silinoid problem right now which is more common then the pump going bad, but if you have the original ProHeat series, then it sounds lik you have a bad pump.
Here's a link to a very, very helpful repair guide directly from Bissell that will explain to you step by step how to trouble shoot, and replace the pump if needed. I would be lost on the ProHeat series without this handy repair guide.
I'm pretty knowledgable now on these machines, if you need some help or some clarification on how to repair this, please feel free to reply to this repair by using the Clarification request form. If you found this helpful, please be so kind and rate my repair, and give feedback.
Here's the link:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-proheat-repair-guide.pdf
Thanks again,
Chris Jones
GoVacuum.com
Posted on Apr 19, 2010
Vac Belts
  • 701 Answers
SOURCE: My Bissell Proheat is not spraying water. What is ...
It is very simple and inexpensive to fix. All you need to do is replace the pump belt. Here is the belt you need:
Bissell Proheat Pump Belt
Posted on May 25, 2010
Bissell, ProHeat, ProTech won't spray water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
895r
Jul 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My bissell stops spraying water, carpet not wet
heatman101
rtetrhgd
May 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hi There,
Here's the link:
Thanks again,
Chris Jones
GoVacuum.com
Apr 19, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell ProHeat 8910 wont spray water or solution
heatman101
sgb
Mar 18, 2010 | Bissell 8910 ProHeat Clear View Upright...
Bissell 1697w Powersteamer
http://www.bissell.com/images/UserGuides/1697_207.pdf
go to bissell.com on the right hand side is the link were you type in your model number. it will take you to it you click more info and it opens a page to access the user guide. i had the same problem and after looking at the user guide found i had a broken belt (near the flow indicator there is a section that can open use a flat head screwdriver to pry it open and you can see the belt) i dont know if that will work yet b/c i just found it so im on the way to get a new belt. hope this helps
Jul 31, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9200 Upright Vacuum Logo
18 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
