Question about Breville BBL600 5Speed Blender
Motor runs blades don't - Breville BBL600 5Speed Blender
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
Blender does not blend, only buzzes. So I took the blender jar off the motor base and tried running it. It ran just fine. Put the jar back on the base and it only buzzed. Figured a piece of frozen fruit...
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Sep 10, 2017 | Oster 006832000000 10Speed Blender
Motor sounds like its running, but the blades
It sounds like a gear might of broken either under the blender jug or in the unit itself. Best bet is seek out an appliance repair shop locally.
Feb 02, 2010 | Krups KB720 5 Speed Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Motor runs but the blade does not spin
The shaft has probably siezed at the bottom near the blade. The seal can fail and let liquid inside the shaft and gunge it up.
Take the orange handle apart, then unscrew the four steel pins, then pull out the motor. From the blade end, take the screw from the blade and prize it off. Then pull the shaft out from the top and clean it. It may be stuck - push a blunt nail or similar in the bottom to free it. Then reassemble carefully
Dec 04, 2009 | Dynamic MD95 Handheld Blender
When trying to blend things like frozen fruit or frozen yogurt with the Vitamix, the blade stops moving, but the motor continues running. Even if there's only enough frozen yogurt to cover the blades, it...
Frozen elements are generally not recommended for blenders of any brand. They may cause the blade assembly to stop moving completely, or to "bog down," and this may eventually damage the motor. It is recommended that frozen fruits and/or yogurt be thawed when possible before placing into a blender. If this is not a possibility for you, I would use a "pulse" or "chop ice" function to rapidly spin the blades for just a moment. This will chop the contents in smaller, more manageable parts. This should be done before adding other liquid ingredients.
Jul 09, 2009 | Vitamix Blenders
Blades won't turn
If the problem is that the blades are jammed and you can't turn them manually, you can let it sit ( and dry out ) for a few days, or you can try adding some oil. I had the same problem and this worked. My problem now is that the blades don't reach to where the motor is turning, so even if they're not jammed the don't turn. If anyone knows and answer to this I'd appreciate it.
Jan 24, 2008 | Oster 6678 14 Speed Blender
Breville BBL600 5Speed Blender Logo
Top Breville Blenders Experts
Mike
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
