Question about Maytag Legacy Series Top Load Washer
Washering machine moves
Washer moves when in use
Remove pedestal from washer
Those washers are heavy! They have weights in them to prevent moving when spinning. Some use bolts through the bottom of the pedestal up through the washer and others use bolts down through the washer into the pedestal. Remove the bolts and lift the washer off the pedestal. You might need to get levelling bolts for the washer or check to see if the bolts are on the bottom of the pedestal. Make sure you get help to move the machine.
Jan 13, 2016 | LG WM2487H Front Load Washer
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
The washer gets unbalanced on small loads that never happaned before a couple of weeks ago. The machine has a unbalance spin load compensator but makes ungodly banging now, that's never happen until...
the problem with small loads is that the tub gets unbalanced very easy,if it spins correctly with a larger load there's nothing wrong with the washer,it's just unbalanced,you can open the lid and move the clothes around by hand to try to balance out the load,very common,also has the washer been moved?check for level,if it was moved one of the legs could have moved to put the washer unlevel,
Mar 08, 2011 | Maytag MAV5920E Top Load Washer
What is the best way to pack an LG washer for moving? I hate to pay someone (though I will if needed) to prepare my LG washer for moving. Are there kits on the market for preparing the washer or does...
reinstall the 4 "shipping screws" on back of unit. they were removed when you had the machine delivered. they hold the drum and prevent it from moving around.
Jul 18, 2009 | LG WM-2277HW Front Load Washer
Amana Front Load Washer moving during spincycle
what is the model # it may be for example, LAT9206BAE
May 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Safely moving a neptune f/l washer
There should be Bolts that run through the back panel that hold the whole tub in place when you move the machine around. Here is a Repair Manual for your Washer. It should help you out in finding the part numbers and where they go when you get them.
Thanks
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Soap leaking out of the bottom of washer
highly likely if you didn't use your shipping bolts when moving your tub cracked bottom of soap dispenser inside of washer buy warrnnty sear about 250.00."less soap plz"
Nov 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Jul 22, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
