Question about Fujitsu Heating & Cooling
Water dripping from unit
Split system Air conditioner unit is dripping water rapidly from vents when turned on
bluenadas
  • 203 Answers
SOURCE: air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Posted on Jun 15, 2007
SOURCE: leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Posted on Dec 31, 2008
SOURCE: rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
Posted on May 11, 2009
daddyo742001
  • 70 Answers
SOURCE: air conditioner dripping water
Try pouring some bleach in drain.
Posted on Jun 28, 2009
motor1258
  • 6674 Answers
SOURCE: My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
Posted on Jul 29, 2009
Celiera 51GW 18000BTU mini split a/c heat, water collects on top rear coil and drips into fan housing and comes out bottom
While cooling, water is supposed to drip off the evaporator coil and flow out the unit. That's a feature of air conditioning. You get a little bit of control of where the water drips to by installing tubing to conduct the water wherever you like, unless the outlet port is plugged up. Poke a toothpick up it and see if that unclogs it.
May 13, 2014 | Haier HEATER CPN10XH9 Air Conditioner
Water flushed from unit inside the room instead of beeing flushed outside throw the out let pipe
Possible that the tilt is more to the front that makes the water drip down. Another reason is that the drain pipe can be clogged with dirt build up and so it flushes back.
Finally if the evaporator is dirty and clogged due to dirt accumulation the water might drip down to the front.
So please check you filter, use high pressure air on to clean and reset the panel.
Aug 27, 2011 | LG LSC121PMA Split System Air Conditioner
Spits out water from the indoor unit
indoor coil icing up .gas leak the water is from the dripping coil . or you have left unit on for to long on a low setting
Nov 10, 2010 | Cfm Daikin R410a Split System Air...
The indoor split system is dripping water what can i do?
There should be a drain pipe to send the condensed moisture outside. Take the cover off the unit and check where the tray is and unblock the pipe.
Oct 05, 2010 | LG LSC121PMA Split System Air Conditioner
Why is water dripping from the overflow quickly
accumulating water is as you assumed - the air conditioner is taking the humidity from the space and the water is nothing other than condensation. I would not worry about it at all.
You need to start worrying if the unit 'doesn't' produce water.
May 14, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Kelvinator aircon is dripping water from air vent in house
Sounds as if unit is freezing over----typically a response to lack of proper ventilation-----check all filters and access panels to unit and clear or clean as needed-----if unit has a drip pan make sure unit has been positioned properly so as to catch excess......properly ventilating unit should resolve issue though
Jan 15, 2010 | Heating & Cooling
Leaking water from inside samsung split sytem
Dec 31, 2008 | Heating & Cooling
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
16 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
