Kenmore 592491070 front load washer
Pump failure, door locked. is there a procedure to get the door to unlock?
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
  • 4090 Answers
SOURCE: Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Posted on Aug 01, 2009
SOURCE: Door lock failure on Kenmore Elite He3
Remember to unplug the machine and to exercise caution when working with water and electricity.
There is a diagnostic mode that is possible to run, it can't run though if you have a door lock error since it will sense that first and not complete the diagnostics.
To start the diagnostic mode:
From machine off.
Press the Drain/Spin button once.
Press the Spin Speed button until No Speed is selected.
Press any of the buttons under Options four times, the same button will need to be pressed each of the times. I use the Prewash button.
Unlocking and locking the door manually:
Front panel below door 3 screws on bottom of panel.
Reach up on right side of drum.
If you pull the tab, ths is manual unlock.
If you close the door, it remains unlocked.
This tab is black, you can't see this unless it is removed.
The black tab pulls on a white slider to unlock, pushing the tab to lock does nothing, you will reach up along the black tab and feel a corner of the white tab, this pushes up easily when the door is closed or if the latch is engaged.
If you engaged the latch and it is closed but not on the door, you will need to pull the black tab down. Then use something sturdy to loop around the white hook inside the latch. I used a black clip that is commonly used for clipping paper or sacks closed, the ones with the chrome loops, just angle it around and pull firmly, remember to have the black tab pulled, but not hard.
To describe the door lock mechanism:
Access to it:
Bottom:
From bottom for manual unlock and lock.
See above on access details.
Top:
From top for removal and installation.
The top panel comes off by three screws from the back.
It then slides back a few inches and then is able to be lift.
Removal and installation:
Three screws from door side holds it in place.
There are three plug-ins to this mechanism, the two white/clear plugs have one press tab each to unhook it and the longer black clip has two on the same side (facing the rear of the machine).
You will move the mechanism into the washer so the close button and the latch area are clear of the face of washer.
There is a cream plastic harness support on the inside that is held by two posts from the mechanism.
The mechanism slides up then out from the harness support.
You need to be careful not to damage the drum seal.
It is out.
Installation is the reverse of removal.
Describing how it works:
You will notice that the mechanism is quite long.
The top part where the wire connector with two wires connected is solitary from the rest, it is just a button to sense whether the door is open or closed.
If the mechanism was opened you will see that the black button has a little tab that pushes a little red button on a rectangular unit when the door is open to keep the connection and is away from it when the door is closed to break the connection.
This should have continuity when the button is in the position of the door being open.
The next set of wires (three of them) power either of two coils of wire to move a metal rod that pulls the white slider up or down.
This slider can only move all the way up if the latch is in the closed position. This is because there is a long metal piece that is spring loaded to block it, when the latch is closed, it allows the white slider to move up. This metal piece is also a guide for the lock mechanism and brings the latch to a metal pin that catches the back end of the latch to hold it in position. The white slider blocks the metal tab when the slider is up, from allowing it full movement of moving the latch away from the pin. If the the black tab or white slider was moved down, it allows room for the metal piece to pivot, move the latch away from catching the pin and when the latch is pulled, to unlock.
The next set of wires (four of them) check whether the slider is up or down. How it works is that if the slider is up, then the top two terminals are bridged on the inside and the bottom two are bridged on the inside, giving you continuity when completely locked. When the slider is down and the latch is able to move freely, then none of the terminals are bridged and there will be no continuity.
I am unaware of how much resistance you need in the door sensor or the electromagnet to slide the rod.
I can say though that you need continuity where described.
If you get no continuity on the upper two or lower two of the four terminals grouped together when the latch is locked and slider up, then there is your problem.
If you have no continuity at the door sensor's two terminals when door is in open position, this may be your problem, but you will need to know the range of ohms and test for this to confirm.
For the electromagnet, you will need continuity from the middle terminal to the bottom terminal and from the middle terminal to the top terminal, if there is none, it will not be able to energize and move the slider. You will need to know the ohms to verify if this is faulty or not.
I am sorry that I do not know the ohms needed.
Warnings:
Remember to have the machine unplugged when opening or working on it.
This information is from my own attempt at figuring out what could be wrong and it may be different than your machine and may not be entirely accurate or complete since I don't have any manuals.
I have not been trained to work on these or any other machines, but I am highly mechanically inclined, but give no warranties to this information. If you decide to work on your machine based on this information, you do it knowing this and I can not be held responsible for any damages or injuries.
Posted on Feb 07, 2010
Macmarkus
  • 2605 Answers
SOURCE: WFMC 3200 Front Load Washer: how do i unlock door? bosch washer was just deliv...
Hi, welcome to fixya. The emergency latch release is behind the small round panel below the main tub door. **Unplug the washer or turn off the breaker before attempting any suggestion given here please** To open the access door ( small round panel ) you'll require a small round needle shaped object or really narrow screwdriver. Put it in the small hole in the panel push in slightly and turn to about 6 o'clock...clockwise that is The small round cover should now come off and expose the pump with the string going through a hook on the pump housing. Be very careful as the edges are very sharp. A string will be threaded through the pump housing and you just need to pull it to open the main door. Let me know how you make out and also if you require further assistance with this problem. If you don't require further assistance and this indeed was helpful to you, please allow a moment to rate this solution I've given accordingly. Thank you for visiting "fixya" today and good luck. Macmarkus :)
Posted on May 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: our kenmore supercapicity 3.5 front load washer's
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
What is error dL f
Doorlock error.
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
I have a service manual and more HERE
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
F- code is on door is locked
Use a wet dry shop vac and attach it to the end of the drain hosse to remove any standing water once the water is removed the door should unlock. then check the drain pump and hoses fro anything restricting or bloxking the drain pump make sure to remove the hose from the front and or side of the drain pump.if you do not find anything then you may need to replace the drain pump.possable door lock and or communication failure with the main control board.
Nov 03, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 417.44092500 front load washer I get a LOC Err
LOC stands for lock....door lock failure....check the door strike and make sure door is closed....if closed wil need to replace lock mechanism
Jun 30, 2009 | Kenmore HE2 Plus Front Load Washer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    Washer wont engage
    The door may not have been fully closed. stop/clear cancel the cycle. ensure door is fully closed and attempt to resart cycle.
    F/dL Door Lock Error
    A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
    • Door Lock Mechanism broken or removed from the Door
    • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
    Feb 08, 2009 | Kenmore HE2 Plus Front Load Washer
    Code F29 is not in the booklet and I can't open the door, is there a way I can fix this because sears can't come out till Thursday, I have so much laundry to do
    code f29 in my book is Door Unlock Error Possible causes/procedure are as follows: 1 door lock mechanism is broken 2. door switch/lock unit failure. a. check door switch/lock unit for foreign objects. b. unplug washer or disconnect power. c. check wire harness connections to the door switch/lock unit and central control unit (ccu) d. check door switch contacts E the resistance of both door coils between pin 1 and 3 should be approx. 320 ohms... the door can be unlocked manually... to do this you 1. unplug washer. 2 remove the lower kick panel (i think 2 screws on bottom hold it on) 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a 1/4 of an inch or until a click is heard. 6 you should now be able to open the door.
    Jan 02, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE4t Washer Control lock lit, door locked
    121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
    Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite HE 3t - error code F dU and door is locked
    Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
    Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    78 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
