Question about Sole Fitness Sole E35 Elliptical
Motor error message
Just plugged in our E35 after it sat in the garage for a bit. Screen comes on and seems to go through a diagnostic page, then goes straight to MOTOR ERROR and will not do anything else?
I have an LT 35 van that has injection problems, the van seems to miss, and engine management light will come on, can this be diagnosed on a diagnostic machine and will it tell me which injector is fa
yes.. you can get an answer from the scaner that they plug under dashboard it probably will say I few codes but 1 of them it will say misfire and the number where you have the problem..
then you just look the diagram for the motor that you have.. and find the wire or spark plug that is damage.
Feb 04, 2015 | Cars & Trucks
F51 diagnostic code meaning motor RPS failure. However, upon running a diagnostic test... everything works properly and goes to the 'done' setting. Also, when doing a load of laundry the machine...
There actually is a class action law suit against whirlpool for this error code well not the error code but the machine itself. I have also had the unfortunate task at one point of fixing this error code. It basicly comes down to replacing the rps sensor, the stator which is the motor, the control board, and in my case I even had to replace the wire harness from the rps sensor to the control board as well. I would try calling whirlpool and see if there are able to provide any support for the machine. Hint while calling them stateing that all you household appliances are whirlpool as well seems to add some leverage. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation. I await any questions that you may have. Thanks Rick
Sep 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I am unable to print and have the following error message Oxc18a0401 come up. How do I solve this?
Try This.
Press and hold the “*” key.
Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the “1”, “2” and “3” buttons.
screen says "support" R0631M
Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
If it didn't print a diagnostic page
Is the error message still being displayed on the printer?
No? Good.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Jul 28, 2010 | Office Equipment & Supplies
My yzf 450 sat a few months in garage I cleaned
The spark plug has shorted.. Just get a new spark plug and all will be well.
Also get new fuel.
Regards
Berry.
Jan 31, 2010 | 2004 Yamaha YZ 450 F
I have a Peugot 206 1.4 sport the engine diagnostic light keeps coming on the engine seems fine> Can I continue to drive the car. Small garages cannot get into the Peugot computer to diagnose the...
Turn the ignition on. Whats the status of service miles? If service miles are reached zero then the diagnostic light comes up to remind you to bring your car to service station. If needed check my other posts to find out the procedure to set off the service /diagnostic light.
Check that the motor oil and oil filter are changed at regular intervals.
For 206 1.4 sports ecu can be scanned by many garages, costs around 45 quids.
Jan 05, 2010 | 1987 Peugeot Liberte
Error code 30 - printer not activated on Cannon 210
E3-3 = Paper jam
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD over current error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
Paper jam error message
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Apr 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Sole Fitness Sole E35 Elliptical Logo
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Brett Duxbury
Brett Duxbury
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
