Question about Gerber Blades Gerber Cornea HI Flashlight 2280122
My flashlight was not used for a year or more. I went to light it and it wouldn't light. I replaced the batteries and it still will not light. Any ideas why? It is a gerber cornea-hi, it has high output L.E.D. and spot to flood printed at the lamp end. Should I return this or is it fixable?
5 Suggested Answers
SOURCE: broke my gerber 3.0 flashlight
Wow what entertainment. Both the poster and the bobint17 don't have a clue how this flashlight works... why answer a question you don't know the answer too? To screw with people? To sound like you know what you're doing?
Anyway, the Gerber TX 3.0 uses a Luxeon 3 LED. There is no bulb. It is not designed as a user replaceable item and unfortunately even someone skilled at soldering and such can't fix the light because the head is permanently attached and not designed to be removed allowing access to the LED assembly. Can the head be removed? Possibly. Will it damage something while trying to remove it with a lot of force? Possibly. Should you try? No. Why? Because the light has a limited lifetime warranty from Gerber. Send it to them and they will fix or replace it!!!
Posted on Dec 31, 2009
  • 157 Answers
SOURCE: how do I change the battery or batteries in a
Hello. The correct way to remove and replace the battery would be to unscrew the end cap all the way. The Battery will then fall away allowing for a new battery insertion. The "plate" is not suppose to be removed (according to Gerber Blades). Hope this helps.
Posted on Apr 11, 2011
  • 157 Answers
SOURCE: How do I replace the
Hello. The "plate" is not supposed to be removed (according to Gerber Blades). The correct way to remove and replace the battery would be to unscrew the end cap all the way. The Battery will then fall away allowing for a new battery insertion. Hope this helps.
  • 157 Answers
SOURCE: how to remove battery from
Hello. According to Gerber Blades, the correct way to remove and replace the battery would be to unscrew the end cap all the way. The battery will then fall away allowing for a new battery insertion. Hope this helps.
How can I fix my rechargeable portable spotlight/flashlight after no charge for 1(one) year?
I replaced the battery in mine(coleman powermate) for 10 bucks but you have to be careful in how you disassemble it and put it back together. Batteries sulfate after awhile like a car battery.
Dec 12, 2014 | Vector Camping, Backpacking & Hiking
The spotlight/flashlight battery may have failed as a result of being unused and not charged periodically.
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
How to replace bulb in garrity stainless steel pen light
I have a Garrity stainless steel flashlight that is approximately 6 inches long. It uses two AA batteries. The light is turned on and off using a push button on the back (push on, push off). The head-end turns to "focus" the light. The lamp, itself, is incandescent. It is 9/16-inch long, including the two 1/4-inch wire leads. The flashlight was purchased 11 years ago, and the lamp just burned out. When I called Garrity, they said they no longer had replacement parts for these flashlights. Which is strange, given you can use Part 2A001 Mineature Bulb G1.27 Base bulbs available from Bulb Town in Jacksonville, FL, as replacements. They work like a champ! If you have any questions, ask to speak to Melinda.
Apr 13, 2013 | Garrity Replacement Bulb
Bought the rechargeable light new a couple years ago, used one time for about 90 seconds. Went to use it again, it was dead. plugged in the battery charger into the cig lighter and it worked after 5 min....
First, ensure the charger is delivering voltage using a volt meter. If it is, the battery is probably bad. If you have soldering skills, the light can probably be disassembled and a replacement battery can be purchased from Radio Shack or online.
Jun 29, 2011 | Camping, Backpacking & Hiking
I had two maglite flashlights, 1 is a (2)D cell light and the other is a (3) D cell light . I went to replace the batteries and I can not get cap off the back ends of both. I think the batteries may have...
the batteries will only go out the bottom -- any attempt to remove the top pieces will most likely result in damage to the light itself. to help in the removal of the BOTTOM cap -- you can try and use a little heat from a propane torch ( not much ) and if you place the end cap into a vise you should be able to get both hands on the top part and give it a good twist. -- if the batteries are if fact corroded in there, get a 2x4 and place it on the gound and tap the flashlight down on it,, this may or may not shake them loose,, all just depends on how long they have been in there. good luck.
c...
Jan 01, 2011 | MagLite Mag-Lite& Flashlight
Repaced bulb and battery light will not come. Switch replaced in 2004
The switch probably went bad again, contact Maglite at www.maglite.com and they will replace it at no charge.
Apr 06, 2010 | MagLite RX3019 Rechargeable Flashlight...
LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
GGBMDB
Apr 05, 2009 | Stinger Streamlight 75000
Gerber Blades Gerber Cornea HI Flashlight 2280122 Logo
Top Gerber Blades Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Gerber Blades Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
