I have an error message saying the waste toner bottle is full...where is it located (how do I access it) to dump it out??
Just an FYI, this can be very messy. If you figure out how to get the thing out (should be near your consumable supplies like toner and image units) place the whole unit into a plastic bag, tie the bag, then shake it out gently. You may have to learn how it opens in order to "open the door". Best to use a vaccum with a heppa type filter as normal vaccum filter is too course for the fine toner partcles. Be ready for toner volcano.
This is for a W2400/3600 which should I assume is the same spec for other Ricoh wide format machines. When you are facing the printer from the front, it's on the right side panel. The waste toner bottle should be about 28" from the ground. Remove all right side panels. There is a sensor (held by phillips screw) that you will need to temporarily remove and reinstall back on to the waste toner bottle once it's emptied. Replace all right side panels. You are good to go. No need to call service tech to waste time. Should be a 30 minute change.
