Question about Volvo VNL 670 730 780 Chrome Mirror Covers see picture
Volvo truck shakes when accelerating
Truck shakes when accelerating. I have changed the fuel filter to support the northern cold weather fuel. I have had the nocsenser changed. the diagnostic test says its not an injector
2005 Volvo S40 shakes when accelerating
Check vacuum leaks and fuel injection system
Jan 14, 2013 | 2005 Volvo S40 T5
No acceleration
Try to clean your car's air filter. If doing that doesn't help, change your fuel filter. Something is choking the engine and its either your air filter or fuel filter. Also try changing spark plugs..
Mar 13, 2010 | 1994 Volvo 940
The motor shakes in my 960 volvo sedan why could that be
A shaking engine usually is an indicator of an engine missfire. Secondary ignition components are the most common failure (Spark plugs, plug wires, etc..). Less likely, but still a consideration are the fuel system components such as the fuel injectors or filter. Further down the list with a vibration in gear at idle are bad engine mounts. If it worsens with engine load such as acceleration then it is likely the ignition system.
Good luck
Oct 30, 2009 | 1995 Volvo 960
Volvo 240 GL Wagon, 1986
Seek good repair shop, too many possibly problem, Sometimes that's the best money spent.ask for a one hour diagnostic check.
Sep 25, 2009 | 1992 Volvo 240
1996 Volvo 740 sputters and shakes when it starts
i think it is your enginemounts. It cured my volvo when i changed them. Ware and tare had softened them over the years
Aug 25, 2009 | 1992 Volvo 240
Volvo 745 turbo wagon stalling?
Fuel Filter yes! Then ck fuel pressure. But it may be a Converter.
Jan 04, 2018 | 1990 Volvo 740
S40 's' reg volvo no power on acceleration
do u have a check engine light? have the fuel pressure tested and also have the fuel regulator tested.
May 13, 2009 | Volvo S40 Cars & Trucks
Volvo VNL 670 730 780 Chrome Mirror Covers see picture Logo
52 people viewed this question
Top United Pacific Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an United Pacific Vehicle Part and Accessory Expert? Answer questions, earn points and help others
