Question about McCulloch Partner Gbv325 25Cc Petrol 3-In-1 Garden Vacuum
Replace pull recoil starter on gardenline blower vac
Blower recoil starter kit
How do I empty the mini shop vac?
Pull out on the clips on each side while pushing on the red part in the center of the clips. Pull black bottom away from the red top while pulling out on the clips.
Dec 11, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
I had to replace the recoil assembly on Electrolux 2000. Recoil works fine by it-self but when vacuum is reassembled the recol does not recoil. Why?
You have assembled it incorrectly and the recoil unit is sticking against something preventing the recoil. It is still tensioned ? Have you checked?
Feb 02, 2011 | Vacuums
NEED TO REPLACE BLOWER FAN FOR CRAFTSMAN SHOP VAC. CAN IT BE DONE?
Yes it can. Below is an item # for a 2HP motor being sold on Ebay: Item number: 280564320553.
If yours is a different HP, do a search on Google for "Shopvac motor replacement". I also recommend that you call sears - maybe your vac is still under warranty? Good luck.
Sep 27, 2010 | Vacuums
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
McCulloch Partner Gbv325 25Cc Petrol 3-In-1 Garden Vacuum Logo
26 people viewed this question
Top McCulloch Vacuums Experts
JoeVacs
Are you a McCulloch Vacuum Expert? Answer questions, earn points and help others
