Question about Toshiba 57HC85 57" Television
Toshiba tv model 57hc85 red linking light - Toshiba 57HC85 57" Television
Projection tv
Please give us some more details about your TV (brand, model etc)
Oct 25, 2007 | Toshiba 57HC85 57" Television
A red tint on my tv screen
Convergence problem. Find honest TV tech.
Nov 09, 2013 | Toshiba 57HC85 57" Television
My tv powers on good, but has no picture
I need some help, no picture, no sound either or what? Also was set doing anything unusual before it failed?
Dec 09, 2012 | Toshiba 57HC85 57" Television
Power comes on but has no picture
The most common issue with these sets is convergence, set will not have sound and power light will be on or off.
Does this sound like your issue?
Dec 04, 2012 | Toshiba 57HC85 57" Television
Where is the coaxial for model number 57hc85 serial no 26101140 chassis no tac 506 we cannot connect a signal at all we bought a modulator rf but it's asking for asking us to connect 1 into the tv but...
After some research http://www.tacp.toshiba.com/tacpassets-images/models/51hc85/docs/51hc85_om_e.pdf There is no coaxial input for this tv. Also as far as the RF Modulator you unfortunatly are trying to use that incorrectly. The RF Modulator is used to convert the RCA or Red Yellow White cables down to Coaxile, not vice versa. However if you have an old VCR or better yet a cable box you would want to hook up the cable box then enter the TV using one of the RCA jacks, HDMI Jacks, or other inputs such as Svid. But easy enough if you have a vcr you can access cable through that as well, and make sure the tv is sat to the correct channel or input to access the VCR or other item.
Feb 04, 2011 | Toshiba 42H81 42" Rear Projection...
Toshiba hometheater 50" rearprojection
http://www.casiasfamily.com/repairlog/tp50h15.html
see the link.
the problem are the convergence amps. Its a common problem for this model. Google the model # and you'll see several postings about the blinking light.
Dec 06, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba 57HC85 57" Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
