Question about Microwave Ovens
Kitchenaid microwave error codes F4 E2
F4 E2 err internal sensor message after popping popcorn
  • 1314 Answers
SOURCE: Will not pop popcorn without burning it
use Orville Rickenbacker ah you know who lol set it for five minutes when you hear it slow take it out works for me no the oven don't need repair popcorn's tough the best way i know to make popcorn is an electric skillet yum yum
Posted on Feb 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave error code
EE4 means the line voltage is too high. Usually this is fixed by resetting the voltage selector on the back.
The voltage selector may not look like a switch, looking rather like a metal panel that has to be taken off and reoriented. There will be a label next to it indicating a voltage number.
EE2 actually means that the control circuit senses that magnetron number 2 is not running.
It doesn't necessarily mean a bad magnetron.
This can be due to a bad or misaligned door switch (common), a failed relay (#3) on the control panel, or a failed high voltage component such as transformer #2, capacitor #2, rectifier #2 or magnetron #2 or loose connections anywhere along the chain.
We have a similar model's service manual on our site. Please not that yours may be different! Part numbers will probably not match. But it will help with safety, disassembly, discharge and diagnosis.
It's here: http://www.microwavedisplay.com/r23gtf_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 01, 2008
SOURCE: magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Posted on Sep 17, 2008
Arius
  • 446 Answers
SOURCE: microwave error message
unplug your unit for 1 minute and plug it back again, you'll be surprised ...it will work again cheers
Posted on Nov 26, 2008
  • 6 Answers
SOURCE: viking professional vmoc205ss convection Cooking POPCORN
You need to use one of the metal racks that came with the Viking microwave to raise the popcorn bag off the bottom of the microwave. It works great!
Posted on Jun 01, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave popcorn
Could be your KitchenAid microwave only works with bagged popcorn.
Jan 22, 2014 | KitchenAid Microwave Ovens
When trying to Popcorn the touch pad is dead and comes up on the display F4?
Its you humidity sensor causing the code:
F4 - Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds, it says to replace the sensor.
You can order it in http://www.repairclinic.com/PartDetail/Sensor-or-Thermistor/253789
Hope this helps.
Aug 11, 2011 | Microwave Ovens
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
During reheat and popcorn settings - the error code F4 appears
Hi hoodrd,
If you are encountering F4 error code from your Amana oven this is because you have an Open Oven Temperature Sensor. This error requires a replacement of new oven temperature. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
Jan 17, 2011 | Amana ACO1860 Microwave Oven
Unit seems to have a sensor problem: wont pop popcorn, or heat cold food but marginly heats water. During popcorn we get error message re. Sensor.
in 99 % of cases the problem is the magnatron it is a very expensive part and unless the microwave is well worth the money we normally write the units off
sorry (
but i hope this helps
best of wishes
please remember to take the time to rank this reply .
Dec 08, 2010 | GE JE1590 Convection / Microwave Oven
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    Controlpanel flashes f 3
    You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
    Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ovens Logo
    51 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
