Question about Refrigerators
Control panel out in gc3phexns00
Control panel does not seem to be working. Not even the on/off button Works when you press it
hotuna
  • 288 Answers
SOURCE: my control panel for the oven does not work(press buttons w/ no response
If the LED display is blank, then you have a power problem. first make sure there is power to the appliance. If you can determine this, then check the transformer on the control module. All these things require some familiarity with electronics and electricity. Depending on you is how to handle this.
Posted on Dec 01, 2007
Master_Tech
  • 770 Answers
SOURCE: Ice Maker? Control Panel?
ARE the dispensing?? your post says yes but if not the 1st thing is to check to see if the water is turned on.. also the valve in the rear of the unit maybe bad let me know
Posted on Jan 26, 2008
IFIXALL
  • 868 Answers
SOURCE: Electronic Oven Control won't work after power failure
Replace the clock.
Posted on May 22, 2008
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: THE CONTROL PANEL ON THE DOOR DOES NOT WORK PROPERLY
there is no program, replace the board.
Posted on Sep 14, 2008
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
HP LaserJet 3055. All of a sudden it stopped working. after powering up, it does "nothing" HP appears in the menu window, but that's it. none of the keys works, no way to even test it. All cables are...
Perform a cold reset
  1. Turn the printer on.
  2. Watch the control panel.
  3. When the memory starts counting, press and hold the green c00007906.gif (Select) button. Continue to hold Select button until all three Control Panel LED's are illuminated and on solid.
  4. Release the c00007906.gif (Select) button.
  5. The control panel will display SELECT LANGUAGE .
  6. Press c00235041.gif (Down Arrow) button until control panel displays COLD RESET .
  7. Press c00007906.gif (Select). The printer will perform a cold reset and then continue its power-on sequence.
Dec 14, 2009 | HP LaserJet 3055 All-In-One Printer
Updated drivers, mouse no longer works, windows xp
Please try to use keyboard to uninstall Driver Robot. Please press the winkey (key with Windows Sign on it), and goto Control Panel with arrow keys and press enter. Now using arrow keys goto Add Remove Programs and press enter. Now navigate to driver robot and use TAB key to select the remove or uninstall button. Please follow the on screen instructions.
I hope this will resolve your problem. Please do rate my solution.
Regards, Rashid
Oct 28, 2009 | Compaq Presario S6000CL (DT072A) PC...
My keypad works,my remote opener does not, even
It is related. One of the buttons on your wall control is the lock button and has a lock icon on it. Press and hold it for 3 seconds. The blinking should stop and your remote should now work.
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Nov 16, 2008 | Samsung AA5900213A Remote Control
2000 Honda Accord A/C acting crazy
if you have it on defrost the a/c will come on even though the a/c light may not even be on
Oct 16, 2008 | 2003 Honda Accord
Having a problem...
Have you try pressing the SAT button?
Feb 10, 2008 | DISH Network IR Remote Control
VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Nov 22, 2007 | Televison & Video
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
