SOURCE: 98 ford mustang spark jumping from coil pack
Hi there:
Misfire is a common driveability problem that may or may not be easy to diagnose, depending on the cause. A misfiring cylinder in a four-cylinder engine is, pardon the pun, hard to miss. The loss of 25 percent of the engine power output is the equivalent of a horse trying to run on three legs. The engine may shake so badly at idle that it causes vibrations that can be felt in the steering wheel and throughout the vehicle.
Basically, it's one of three things: loss of spark; the air/fuel mixture is too far out of balance to ignite; or loss of compression. Loss of spark includes anything that prevents coil voltage from jumping the electrode gap at the end of the spark plug. Causes include worn, fouled or damaged spark plugs, bad spark plug wires or even a cracked distributor cap. A weak coil or excessive rotor gas inside a distributor would affect all cylinders, not just a single cylinder.
Lean misfire can occur when the air/fuel mixture is too lean (not enough gasoline in the mixture) to burn. This can be caused by a dirty, clogged or inoperative fuel injector; air leaks; or low fuel pressure because of a weak pump, restricted filter or leaky pressure regulator. Low fuel pressure would affect all cylinders rather than an individual cylinder, as would most air leaks. A leaky EGR valve can also have the same effect as an air leak. In fact, if a vehicle has one or more misfire codes and a P0401 EGR code, the fault is likely carbon buildup under the EGR valve.
Loss of compression means the cylinder loses most of its air/fuel mixture before it can be ignited. The most likely causes here are a leaky (burned) exhaust valve or a blown head gasket. If two adjacent cylinders are misfiring, it's likely the head gasket between them has failed. Also, if an engine is overheating or losing coolant, it's likely the head gasket is the culprit.
Intermittent misfires are the worst kind to diagnose because the misfire comes and goes depending on engine load or operating conditions. They seem to occur for no apparent reason. The engine may only misfire and run rough when cold but then smooth out as it warms up. Or, it may start and idle fine but then misfire or hesitate when it comes under load. Also, it may run fine most of the time but suddenly misfire or cut out for no apparent reason.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
SOURCE: spark jumping from coil pack
Hi there:
SOURCE: No spark to front coil pack
Judging by your question you have automotive experience though for safety sake I will have to state some precautions anyhow. With the engine running and in park with the emergency brake set. Check your working coil packs "hot" wire with a multi meter. Set to 12 volts and check amperage and volts delivered. I would recomend checking each of the working cylinders if possible to establish base line readings. If you are receiving similar readings on the down cylinder then you have a short in the coil pack and it will need replaced. If you are not receiving a similar voltage and amperage you likely have a short and should trace the feed wire for that coil. As with all repairs if you are not absolutely sure of your capabilities to fix the problem you should seek the help of a professional. Happy motoring.
Testimonial: "Yes I have some time working in auto dealerships. That's exactly where I'm at tracing the wiring now. Thanks for your suggestion, I'll re-post the fix when I find it"
