Question about Janome Hello Kitty 15822 Heavy-duty Aluminum 22-stitch Sewing Machine color - white with red trim
What to do when the needle is stuck down through the fabric and will no release
    Champion:
  • 276 Answers
Be careful, release needle clamp and slowly rock the hand wheel. use tweezers or small pliers to hold needle and gently twist/pull as the wheel is rocked. The needle will loosen and come out with patience, use as little force as possible
Posted on Feb 19, 2014
My fabric is stuck down inside where the needle goes
Try to remove the needle from the needle clamp. And, try to remove the bobbin case from the machine. Then slowly and gently snip the threads that are holding the needle in place. Do not yank or pull on the fabric as it could damage your machine.
Mar 26, 2017 | Sewing Machines
Tension on the side does not release the cotton when machine is stopped, making it difficult to pull out the job.
Be sure to always RAISE the Presser Foot when threading the machine or when removing fabric. When threading or removing the fabric, try raising the needle to its highest point. Raising the presser foot releases the tension disks. When the presser foot is down, the tension disk is engaged and will not release the thread.
May 23, 2016 | Sewing Machines
Why does the fabric get stuck in the feed dog plate?
try changing the needle it could be blunt
also make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin are for lint
Mar 24, 2016 | Brother Se425 Computerized Embroidery &...
Sewing machine jammed with needle down and material can not be removed. Help I can break the needle, I really just want the fabric out.
loosen the needle clamp screw then you can pull the needle out with pliers not damaging any of the machine or bobbin area .
Oct 30, 2015 | Singer Sewing Machines
Why does stretch fabric keep getting stuck in needle plate?
Your needle may have a slight niche in the end. Run your finger around the tip on the needle. Good Luck...xo
Sep 19, 2014 | Sewing Machines
Needle arm stuck
Firstly, do you pull the fabric as it goes through the machine; this is a surefire way to break needles. Tension imbalance shouldn't be breaking a needle; more likely the thread would break if the top tension is too tight. And botton tension shouldn't need adjusting at all.
It may be that your needle is striking the presser foot if you are applying some "pull" to the fabric at the back of the foot.
But sewing very heavy fabrics is a challenge for many domestic machines - upholstery, heavy denim and canvas is tough going for many machines. Some tough mechanical machines will manage it but many won't. You can try using a roller or walking (even feed) foot as this may help with moving the fabric through but often the feed dogs just can't grip and move the heavy fabric enough. If you need to sew heavy fabrics regularly maybe consider finding a 2nd hand industrial straight stitch machine such as the Singer 20U.
In the case of your Bernettte, remove the needle plate (two screws), pressure foot, stub of needle and bobbin and then search the bobbin rotary hook area and see if there is a piece of needle stuck anywhere, you may need to turn the machine upside down and see if it falls out of the race area. I think this machine has a plastic horizontal bobbin case ??? If so, you will probably find that this has dislodged and may have been struck by the needle so remove it and give it a good visual check for damage, if there is a pierce mark, then give this a file down with an emery board to smoooth it. While it is out, see if the flywheel will now rotate the rotary hook fully.
Then reassemble by putting the bobbin case back in lining up the mark on the case with the stopper in the rotary hook, replacing the needle plate, pressure foot and a new needle.
If you can't get it to unlock at all, then it will need to go to a technician for repair.
Nov 07, 2011 | Bernina Bernette 75
When the needle descends it gets stuck as it enters the bobbin case area. It will only release if I move the bobbin. The thread from the needle gets knotted up and pulls the fabric down into the bobbin...
Could be a few things. Absolutely minutely check that the top thread is threaded properly. Otherwise, it could be: Old thread. incorrect thread for the material. wrong size or blunt needle. or incorrect tension on needle I had this problem and I was missing a part of threading even though I have been sewing for years. :)
Oct 08, 2017 | Brother LS30 Mechanical Sewing Machine
The needle gets stuck and I have a hard time removing the fabric. How do I oil the machine?
As far as oiling goers you should oil all the moving parts that you can see, if the needle gets stuck run the machine without fabric and thread and see what happens, if the needle get stuct you may need to retime it, if it only gets stuck when you are sewing make sure you are not pulling the fabric to the back instead of letting the machine do the work.
Mar 10, 2010 | Sewing Machines
Needle Sticks - Huskystar E10
When it feels like the needle is jammed, open the bobbin cover and release the two black retaining levers, one on either side of the bobbin case. The hook cover that is visible will be released. If the machine turns by hand smoothly, you may have a piece of the broken needle, or just a piece of thread stuck behind the hook or hook cover causing the bind. This problem will sometime make you swear that the needle is stuck in something because it will usually bind while the needle is down in the fabric.
Apr 04, 2008 | Husqvarna Viking 1
Janome Hello Kitty 15822 Heavy-duty Aluminum 22-stitch Sewing Machine color - white with red trim Logo
56 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
