Question about Hayward SAND FILTER, PRO SERIES
Pantera pool filter model p24
Top valve.I need replacement or replacementgasket
    Top Expert:
  • Hayward Master
  • 4,292 Answers
Give them model number of filter and multiport you need new multiport gasket (spider gasket)
Posted on Mar 05, 2016
3 Suggested Answers
  • 333 Answers
SOURCE: removing my filter valve and checking why sand is
On mine the whole unit just un-screws
Posted on May 29, 2010
  • 4044 Answers
SOURCE: I have a P20 Pantera
The last time I saw this there was a valve problem on the controller and the filter sand needed changed. If that sand has been in there more than 12 months and running most likely the sand needs replaced. While you have it open you can check the pipes and fittings in the Filter Unit to make sure something didn't come loose. If I remember correctly it recommends changing the sand every 2 to 3 years unless there is a lot of build up which you described indicating the need to change it. The 2 to 3 year recommendations comes not so much because of the sand but to inspect the inside of the filter unit as well.
Posted on May 25, 2011
Please where can I find valve body lower part no. 14965-0013 for my pantera sand filter
So sorry, this part is No longer available.
Has been... Obsoleted, Discontinued, Cancelled all production, Ixnayed, I think you get the picture.
Anyway, your option is to either get a whole new filter assembly with a new valve, or just a new valve...?
This one is the replacement for your filter tank. New and improved. Oooohh.
Take a look, some re plumbing will be required. One draw back : (
No Unions : (
Pentair 261186 Valve Replacement Sta Rite Cristal Flo High Rate Pool and...
Jun 10, 2015 | Pool & Spa
Rubber web like gasket under control lever, provider needed
that is called a spider gasket, generically!, So Good Guess!
Any Pool & Spa Supply store should have or could get one.
Amazon is a good place if you are an online shopper...
Amazon com Sta Rite filter spider gasket
You will need to know the size of your valve... 1.5" or 2.0 "
May 25, 2015 | Pool & Spa
Pantera wicor model no. P24
if not able to get seal check hardware store for oring or replace unit
Feb 09, 2014 | Hayward SAND FILTER, PRO SERIES
Colliquip p24 pool filters
remove top of multiport clean old one out check to see if new one has to be glued then replace
Aug 03, 2013 | Sta Rite Pool & Spa
Pantera pool filter manual
Exactly where is the pump leaking?
If it is leaking between the wet end and the motor then you need a new shaft seal sometimes referred to as a mechanical seal.
You will need to know the brand of your pump when you start searching for the replacement.
Rod
US Parts Center
May 06, 2013 | Hayward SAND FILTER, PRO SERIES
Have a pantera p24 sand filter from wicor and the lable has gone from the control lever. I need to know what function is in each position.. filter, rinse, backwash etc.
don't know if you got it fixed or not but can give you mine....if your looking at it from the top it goes like this....in the twelve o'clock position nothing,1 o'clock is recirculate then 3 o'clock is backwash then 5 o'clock is close then 6 o' clock winterise then 7 o'clock is waste then 9 o'clock is filter then the 10 or 11 o'clock is rince. hope that helps..
Jul 15, 2011 | Wicor Industries Master Plumber Geyser...
When filtering water it is also leaking through back wash pipe it is a sand filter pantera hi-rate filter with sta-rite water flow control
Is this a multi-port valve offering back wash, no filter, rinse, etc. modes? Have you ever turned it counter clock wise? (Never turn it counter clock wise.)
You will need to remove the top and put a new gasket in the valve.
If it is Push Pull, remove the two screws at the top and pull the assembly out. Remove and replace all "O" rings. Lube with silicone grease for pools and reassemble.
I think this will fis you up.
Thanks for your question today.
Jan 30, 2011 | Sta Rite Pool & Spa
Labels Gone
I also have the same problem with the label on my filter. My pool dealership said I would need deal with Wicor directly. I see two other people with the same problem, however, neither has been responded to. It is VERY difficult to run your pool properly if you don't have your control lever labeled. An immediate response would be greatly appreciated.
Apr 23, 2010 | Wicor Industries Master Plumber Geyser...
My filter and pump will not retain the prime after turning off. Its a pantera sand filter. I can hear an air hissing sound coming from the multi valve port
Either you have a bad spider gasket inside the multiport valve or a bad threaded fitting going into it. Check for leaks around the multiport and backwash line. You'll have to take apart the multiport valve to make sure the spider gasket is not damaged or out of place. Make sure to install the multiport valve in the same position. You can get a replacement gasket at most pool supply stores or online.
Oct 29, 2009 | Hayward Pool Products HAYWARD HEAT PUMP...
Hayward SAND FILTER, PRO SERIES Logo
85 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
