Question about AudioCodes MP-118-FXO MediaPack Analog VoIP Gateway 4FXO SIP Router
Audiocodes mp-118 fox and fxo certificate files
4 Suggested Answers
dante777
  • 623 Answers
SOURCE: AudioCodes MP-11R/2FXS
The easiest way (if enabled) is to use the voice menu as if you would assign a new IP to the device.
  1. Connect a telephone to one of the FXS ports. Lift the handset and dial ***12345 (three stars followed by the digits 1, 2, 3, 4, 5).
  2. Wait for the 'configuration menu' voice prompt to be played.
  3. To change the IP address, press 1 followed by the pound key (#).
  • The current IP address of the gateway is played. Press # to change it or hang up if you don't want to change it.
  • Dial the new IP address; use the star (*) key instead of dots ("."), e.g., 192*168*0*4 and press # to finish.
  • Review the new IP address, and press 1 to save it.
Of course you can try the default IP of 10.1.10.10 if the device is set to it's default standards.
If not, you can try a network scanner like angryip (link) or network scanner (link) - this might take a long time, since the IP can be virtually anything.
If you have physical access to the device, you can also use a straight RS-232 cable to connect the AudioCodes to your PC and use HyperTerminal to connect (Baud Rate: 115,200 bps (MP-124), 9,600 bps (MP-11x), Data bits: 8, Parity: None, Stop bits: 1, Flow control: None)
If you need the manual (and it never hurts ;-) here is the link:
http://www.audiocodes.com/filehandler.ashx?fileid=36320
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Oct 23, 2009
SOURCE: AUDIOCODES MP-118 FXO
Hi, I am using Audiocodes MP-118 FXO too
Man, check the Reverse Polarity.
1st.- Go to Protocol Management
2nd.-Go to Advance Parameter
3rd.- Go to General Parameter
4th.- Go to Enable Polarity Reversal and select ENABLE
5th.- BURN and RESET
You have FAS calls, because Reverse Polarity is disable.
Lucky
Posted on Nov 04, 2009
Tauqeer
  • 496 Answers
SOURCE: pls how can i reset my audiocode mp-118 back to
First of all unplug the network cable.
Then take a pin or a needle and insert it into the pin whole which is intended for reset. Insert the pin inside the pin whole and press at least for 6 seconds. All the LEDs (Light emitting diodes) or the tiny lights will glow brighter while the reset button is being pressed by the pin. The device will reset. After reset the red LED may start to blink bright.Be careful and be patient as all the LEDs are normal before you plug in the network cable.
Good Luck!
Posted on Jul 26, 2010
Cannot reset to factory default
Are you unplugging ethernet cable from MP? make sure you do otherwise factory reset will not work.
May 22, 2012 | AudioCodes MP-114-FXO - 0 FXS Ports, 4 FXO...
Can I reprogram a rt31p2 router from vonage
No there is no way to do this, no software to do the job exists.
Dec 29, 2011 | AudioCodes MediaPack MP-114 FXS and FXO...
Unable to access a fresh Audio codes box via http using default IP address.
What IP address are you pointing at? 10.1.10.10? 192.168.0.1? try with 10.1.10.10 and worst case scenario install wireshark on your PC and take a trace when connected directly to MP and power it on, there you will see some bootp messages (IP address 0.0.0.0) and after that you will see messages from MP announcing its IP address. If device is brand new you should login fine using Admin / Admin. Beware that some internet explorers do not allow login even with right user/password, try with a couple of them.
Aug 22, 2011 | AudioCodes MediaPack MP-114 FXS and FXO...
Pls how can i reset my audiocode mp-118 back to factory deffault. because i have try to look for the latest firmware on www.audiocode.com in order to upgrade it. unfortunately i didnt find any.
Good Luck!
Jul 26, 2010 | AudioCodes MediaPack MP-118-FXS Router...
My mp-114 dials 5252 when I access a line. Do you
You may have enabled the "auto dialing" feature and may have that destination configured. Please post your INI config file and I will be able to assist you further.
Aug 07, 2009 | AudioCodes MediaPack MP-114 FXS and FXO...
Lucky
May 28, 2009 | AudioCodes MP118 Analog Modem
Way to reset mp-114 audio code to factory settings and configure
Unplug the network cable and hold in the RESET button (small hole on back of unit) with a paperclip for 6 - 10 seconds. The default IP is 10.1.10.10 sm 255.255.0.0 if it is an FXS
10.1.10.11 sm 255.255.0.0 if it is an FXO
May 16, 2009 | AudioCodes MediaPack MP-114 FXS
AudioCodes MP-118-FXO MediaPack Analog VoIP Gateway 4FXO SIP Router Logo
20 people viewed this question
Top AudioCodes Computers & Internet Experts
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
