Question about Sony KP-57WS520 57" Rear Projection HDTV-Ready Television
Sony KP-57WS520 - Sound, NO VIDEO
I have just purchased this TV used.  In 'Twin View' the right side or picture is fine with both Video and Sound.  The left side has sound but no Video.  This is preventing me from seeing the picture in full view.  Video 5,6,7 are the ports in which this problem is occuring. I have called around to numerous companies in San Antonio and they are all telling me that it is going to be expensive.  Is there something like a quick fix or can someone tell me what to look for.  I have done some research on my own but still feel like I don't know what the actual problem is....Suggestions
MikeNJ1964
  • 398 Answers
SOURCE: Sony 57 in Rear Projection TV
If the picture is playing fine and you notice that the background is getting more and more red, until it is too red and the set shuts down, it could be that the red screen control is set just a bit too high. If this is the case, you can probably correct this yourself. If you are watching a perfect picture and then it suddenly flashes a very bright red, with thin red lines in the pictureand then shuts down, it usually means that the red picture tube has developed a short in it, between the cathode and heater. A good tech might be able to remove the short by arcing, but if the short persists then the red tube will have to be replaced. Either way, this is something that should only be done by a qualified tech.
Posted on Aug 27, 2007
  • 2337 Answers
SOURCE: Sony KP-57ws520 with standby light 9 blinks
To be more specific, you will need to find D6116 or D6301 located on the G board, they might be open and will need to be replace.
You can request a service manual from this website.
If you need further assistance, le me know.
Posted on Aug 18, 2008
welcomejee
  • 10594 Answers
SOURCE: The Video display stays on the TV
If it is Sony TV then press " i " or Display button on TV remote and on-screen display will disappear.
Posted on Jan 13, 2009
  • 1043 Answers
SOURCE: Picture too large for screen on Sony KP 57WS520
If you are using a cable or satellite receiver to tune your channels, they have settings that may be causing the problem. There should be a menu option for System Settings or something similar. Make sure that no type of Zoom has been turned on. Also ensure that your type of TV is set properly. If your TV is a Widescreen then make sure either that or 16:9 is chosen. If all of those settings are correct, and there is no Zoom feature is turned on your TV then there maybe an internal issue with the TV. You'll have to get a technician in to find the problem or check the internal settings that only he can access.
Posted on Jul 27, 2009
welcomejee
  • 10594 Answers
SOURCE: KP-57WS520 Sony Projector - No picture
5 times blinks shows incorrect white balance (AKB) error. TV needs Screen Volts (G2) adjustment.
Take off lower front panel, find Focus Block that has 6 control knobs, adjust Screen volts of each CRT (red-green-blue) and problem will be solved.
Be Careful while working in TV.
Let me know if you have further question.
Thanks.
Posted on Dec 09, 2009
Testimonial: "Unfortantly didn't do the trick, during quite a few adjustments as you suggested, I would get a error code 10. Any feedback on this new code?"
My I got sound but no picture on my DVD player
There are three coloured leads on the back of a DVD player if you use composite video - Red is Right channel sound, white is Left channel, yellow is video.
Red from DVD right output to TV right input
White from DVD left output to TV left input
Yellow from DVD video out to TV video in
Sep 03, 2012 | KLH DVD8350 DVD Player
My sony tv trinitron has a picture inside of the picture how do i remove it?
This is probably a result of the TWIN VIEW feature being enabled on your TV.
In order to disable this feature, normally you just have to press the TWIN VIEW button again on your TV's remote control.
Here is a link to the USER'S MANUAL for your Sony TV which has the complete instructions for controlling that and other features:
http://www.docs.sony.com/release/KV36HS510.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 40 of the manual for a labelled diagram of the remote control showing the various button functions. TWIN VIEW button is #19 on that diagram.
See page 47 of the manual for detailed instructions and illustrations on how to use the TWIN VIEW feature. on your set.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Oct 11, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Thanks.
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
My sony Wega KP-57WS520 TV blinks 9 times and the picture and sound won't come on.
the blinking is an error code telling you that tv needs a new power supply.. have your tv serviced...
Nov 17, 2009 | Sony KP-57WS520 57" Rear Projection...
Hi i have a krf-v5030d and i am having trouble woking out how to connect it to my panasonic 37'' plasma th37px70b and my sky plus box can you help me please .thanks john
Hi John,
I have the same amplifier, a Sky + HD box, an LCD TV an surround speakers. We wont go into the Wii, PS3 and PC also hooked up. Essentially the best way to go (whatever you connect up) is to split the video and audio signals.
Sky: The Sky box has an audio outputs (left and right channel) found at the back of the box. You get some twin audio cables, plug into the back of the Sky box and the other end into the Kenwood Amp (for example we use Video 1). This means that the sound from Sky can be found on Video 1 on the Amp.
You take the video signal (picture) from Sky using a SCART cable and put into the back of your panasonic TV. This does mean that you can watch a picture without the sound and listen without a picture. The Amp remote controls the sound, the Sky / TV remote controls the picture.
You may need to tinker with some settings on the Amp, for example on the front of the Amp you will find a source button, toggle through the 3 or 4 options to give you the right sound. But essentially that should be it. The same process is used for any other things you want to add, like a DVD player, a games console and so on.
Hope this helps.
Regards, Mohammed
Oct 05, 2009 | Kenwood Audio Players & Recorders
Sony 65
Type in toolbar Understanding Sony Blinking Codes this will take you to Sony post telling what is wrong with TV depending on how many Blinks.
Sep 18, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony KP-57WS520 57" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
