Question about Sharp Carousel R530EST Microwave Oven
Wont turn on at times - Sharp Carousel R530EST Microwave Oven
Vent fan wont turn off
Steve,
The vent fan is thermostat controlled to protect the control panel. Once the panel temp drops, this will turn off by itself. This is normal for this to occur when your steaming and cooking for a long time. Good Luck
Apr 22, 2014 | Maytag Over-the-Range Microwave
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
Starts when closing door
This is a list of possible causes. 1. Defective triac or relay 2. controller is confused (pull power cord for a minute and see if it resets) 3.Defective controller or touchpad.
Mar 02, 2010 | Microwave Ovens
Wont work
Don't know this particular model, but it sounds like you are just pressing the time buttons for cooking and not actually setting the time clock which is what it's asking for. Are you following the instructions for setting time as detailed in your instruction book?
Oct 20, 2009 | Whirlpool Microwave Ovens
Panasonic nn-s255 wont turn on
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
Sep 08, 2009 | Panasonic NN-P295SF Microwave Oven
Microwave wont kick on unless I push the door up
Hi, this is a faulty door latch assembly. the switch is malfunctioning. the entire door latch assembly will need to be replaced.
Jun 21, 2009 | Amana ACO1520A Microwave Oven
Child lock??
Any suggestions? Yes. dump it. It's too old.
Jul 18, 2017 | Panasonic NN-S563 Microwave Oven
FAN!!!
Oh, it turns out the the microwave was over heated and the fan was cooling it. The fan will automatically turn on and stay on until your microwave reaches normal temp. just unplug your microwave and let it cool off. then plug it in and everything should be just fine.
May 25, 2008 | Frigidaire GLMB209D Microwave Oven
Sharp Carousel R530EST Microwave Oven Logo
12 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
