Question about Kenmore Washing Machines
What does dc code mean for top load washer 592-29222
What does dc code mean for Kenmore top load washer 592-29222
SOURCE: for the kenmore elite oasis
We jamed a straw in the door lock so the sensor thinks there is something in there
Posted on Jul 03, 2008
duby1990
  • 367 Answers
SOURCE: Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
SOURCE: Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
Posted on Apr 03, 2010
FAV6800AWDIY
  • 526 Answers
SOURCE: Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
Posted on May 23, 2010
rickead1
  • 1998 Answers
SOURCE: my HE2 kenmore front load washer shows a code of
check the water tempreture sensor and connection to it
heres some info that should help ya
http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
hope this helps
pdf.gif HE2 Error Codes.pdf
Posted on Jul 18, 2010
What does error code dc mean?
DC error code means: "Unbalanced load". It can occur if the washer:
1. is overloaded (too many clothes inserted),
2. can't balance the load within a few balance cycles,
3. has a damaged balance sensor,
4. isn't regulated properly (vibrates abnormally).
IMHO you just overloaded the washer :)
Jan 19, 2015 | Samsung Washing Machines
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
While in the middle of wash load, an error light appears. Sd, what does this mean? kenmore top load washer model 8567165
A code of "SD" indicates the washer has entered its "Suds Routine." That happens when an excessive amount of suds is detected in your washer, and the machine changes operation to remove the suds for proper rinsing of your load. The code will clear itself once the "Suds Routine" has finished.
If it keeps doing this each load, try lightening up on the detergent.
Oct 08, 2013 | Kenmore Oasis HE 27082 Top Load Washer
What does FE code mean?
KENMORE TOP LOAD WASHER WITH FE CODE WHAT DOES THAT MEAN?
Sep 17, 2012 | Kenmore Elite 45986 Front Load Washer
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
What does UL code mean on washer?
What does error code UL mean on digital Kenmore Washer?
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
F1 mean on 110.2706
on oasis u have to replace the main board
Oct 04, 2009 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Maytag neptune tl washer
A dc error means that the clothing is not being distributed properly in the basket. This usually happens when the machine is lightly loaded. If the load seems o.k. then the problem is probably with the sensor at the side of the basket.
Apr 26, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
