Question about Panasonic 50 in. Plasma TV
8 blinks tv blinks eight times then shuts down but nt all the time
5 Suggested Answers
  • 8457 Answers
SOURCE: panasonic th-50pc77u red light blinks 8 times in cycle
Ur power board it dead,need it replaced.
Posted on Nov 23, 2009
denisgomes
  • 28 Answers
SOURCE: Picture and sound go off
The TV might be telling you that there's something wrong with the power (wrong or excessive voltage, for instance). Please test the TV at someone else's house to rule out electricity problems at your house. If the TV still shuts off, then there should be something wrong with its logic board or power circuits, and you should call a technician to inspect it.
Posted on Mar 02, 2011
  • 1156 Answers
SOURCE: tv cuts out after 25 minutes red button on front
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
Posted on Sep 24, 2011
gopakumarg43
  • 74211 Answers
SOURCE: how to fix TH-58PZ700U 58 in. HDTV Plasma Television blinks 10 times
With Panasonic Plasma TV, 10 blinks swill never occur. It shoud be either 9 or 11. Count it once more. Visit the site named 'Electro-help' for more details. Click this link. View it in Timeslide or Flipcard option, which can be selected from the drop down box menu by the Sidebar tag, at the top left corner of the display window. You can also click the Home tab to see the latest updates. It will make search easier. There are more than 1400 posts to different brand TVs till now. Setup proceedings and code list to different brand remote controls also included. Pull up older posts or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Posted on Dec 14, 2012
TV will not come on
There are a couple of different things that could cause this problem, the first is the power supply, and the second the main board. There's no easy answer on this question. Have it serviced at repair shop.
Mar 30, 2015 | Panasonic Televison & Video
My sony KP-51HW40 TV shuts off
the eight blinks indicates you have a high voltage error. you will need to replace the d board. the part number is A-1348-038-A.
Oct 30, 2007 | Sony KP-51HW40 51" Rear Projection...
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Tv shuts down and i have to turn it on and change channels to get a picture and the color is fading
Hello
It system memory IC has the trouble. It is an eight solder terminal IC, can be located very near to the main system control IC. Replace it with same number. Its' number is most important to note, when you buy a new one.
A skilled job indeed.
Feb 15, 2012 | Sony FD Trinitron WEGA KV-32FV310 32" TV
51ws500 sony shuts down and standby light flashes 8 times
Eight blinks points to an audio output problem. The unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Hope that helps.
Feb 20, 2011 | Sony KP-51WS500 51" Rear Projection...
Turns red then shuts off
the red CRT is shorted . You should be able to get a replacement CRT at the following link.
http://servicemanuals.vstore.ca/
Sep 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Green screen and shut down
TV screen flashes with Red lights for few times. sometime it shut down TV or red color is lost showing pictures without Red looks terrible. Any solution
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv shuts off by itself then flashes a code 8 blinks
Eight blinks means, "High voltage error". The probable cause location listed is "T8005 is faulty (D board). T8005 is the fly-back transformer (FBT). or you can replace the full d-board
You may purchase the D board complete for $185.10
or send in for repair here
if one of the crt is shorted it can also cause this problem.
Jan 30, 2008 | Sony KP-57HW40 57" Rear Projection...
Panasonic 50 in. Plasma TV Logo
14 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
