Question about Hayward SAND FILTER, PRO SERIES
Pantera pool filter manual
Can you supply me a replacement top valve or gasket, seal is worn and water is spraying out.
SOURCE: Hayward sand filter needs primed every time
The problem is a malfunctioning check valve. It'll be somewhere in the line on the pump output side. If it's not a separate fitting it'll be in the line, probably in an elbow.
Need further info, let me know...
Charlie
Posted on May 29, 2009
  • 93 Answers
SOURCE: filter is shooting sand back into the water when
SOUNDS LIKE YOU ARE IN RECIRCULATE MODE TAKE HANDLE AND MOVE IT TO ALL THE POSITION TO TEST BACK WASH CYCLE ETC SAND SOULD BE FINE CHECK TO SEE IF YOU HAVE ENOUGH
Posted on Jun 19, 2009
john224
  • 1378 Answers
SOURCE: Hayward S244T filter spraying water at top
Just an o-ring and the 2-piece clamp that compresses the two pieces together.
Posted on Jul 28, 2009
  • 990 Answers
SOURCE: Hyward Variflow valve lets water drain when in filter posi
If you pull the six screws holding the valve top on and open it up. You will see what is called a spider gasket in the bottom of the valve and this is comming loose. If you pull this out and dry the valve. You will have old silicone in the grooves at the bottom. Carefully clean all this out. Take the old one to the store to match it up. Then put a thin layer of silicone on the new one and put in place. Reassemble and let sit for a few hours and you should be good to go.
In the future be shure the pump is off and all the presure is out of the system before you turn the valve. The water inside will resh over the gasket and pull it out of place causing this. So be careful. good luck.
Posted on May 13, 2010
jharwell668
  • 640 Answers
SOURCE: problems with hayward vari flow valve.
It sounds like you might just need to replace your valve. They are fairly inexpensive. Try contacting this company. They will be able to tell you exactly what you need to do (free advice) and will have the parts necessary if you do need to buy a new pool filter or new parts.
Backyard City Pools 888-751-0101 or www.backyardcity.com
Just let them know that you need to speak with the person in charge of pools. He will be able to help.
Posted on May 24, 2010
Rubber web like gasket under control lever, provider needed
that is called a spider gasket, generically!, So Good Guess!
Any Pool & Spa Supply store should have or could get one.
Amazon is a good place if you are an online shopper...
Amazon com Sta Rite filter spider gasket
You will need to know the size of your valve... 1.5" or 2.0 "
May 25, 2015 | Pool & Spa
Pantera pool filter model p24
give them model number of filter and multiport you need new multiport gasket (spider gasket)
Feb 09, 2014 | Hayward SAND FILTER, PRO SERIES
Pantera wicor model no. P24
if not able to get seal check hardware store for oring or replace unit
Hansgrohe axor repair
follow this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals.
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 26, 2013 | Home
Jameco single handle kitchen faucet with spray hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
Jameco single handle kitchen faucet with spray is hard to turn
The water coming out the shower jets is not powerful, help?
If a faucet leaks, replace seals and gaskets .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
When filtering water it is also leaking through back wash pipe it is a sand filter pantera hi-rate filter with sta-rite water flow control
Is this a multi-port valve offering back wash, no filter, rinse, etc. modes? Have you ever turned it counter clock wise? (Never turn it counter clock wise.)
You will need to remove the top and put a new gasket in the valve.
If it is Push Pull, remove the two screws at the top and pull the assembly out. Remove and replace all "O" rings. Lube with silicone grease for pools and reassemble.
I think this will fis you up.
Thanks for your question today.
Jan 30, 2011 | Sta Rite Pool & Spa
My filter and pump will not retain the prime after turning off. Its a pantera sand filter. I can hear an air hissing sound coming from the multi valve port
Either you have a bad spider gasket inside the multiport valve or a bad threaded fitting going into it. Check for leaks around the multiport and backwash line. You'll have to take apart the multiport valve to make sure the spider gasket is not damaged or out of place. Make sure to install the multiport valve in the same position. You can get a replacement gasket at most pool supply stores or online.
Oct 29, 2009 | Hayward Pool Products HAYWARD HEAT PUMP...
With filter set on "FILTER" water is escaping out backwash port contiualy lowering pool water level.
Your question was posted under "Pond and Water Garden Pumps", but I assume you are really asking about a swimming pool filter. Unscrew the control valve from the valve body and check the condition of the O-ring. If it is nicked, torn, or worn allowing water to flow past the valve, buy a replacement at your local hardware store or swimming pool supply. Pop the old one off, and put the new one in the track where the old one was. If it doesn't want to stretch to fit, put the new seal in HOT water for a few minutes and try again. Lubricating the O-ring with some Vaseline or other brand petroleum jelly will make operating the valve easier and cut down on wear of the new seal.
Jun 28, 2009 | Hayward Sand Filter System & Tank 21" 1...
Hayward SAND FILTER, PRO SERIES Logo
21 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
