Question about Idylis 2.5-Gallon Ultrasonic Humidifier IHUM-20-25
IHUM-20-25 will not power on - Idylis 2.5-Gallon Ultrasonic Humidifier IHUM-20-25
How can I get an owners manual for this humidifier?
'This humidifier'? The one you have in front you that we can't see and don't know what it is?
Google is your friend in such cases. Google
Make model manual.
Feb 09, 2016 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Mine is leaking badly. It is not overfilled. any ideas why?
It most likely it the valve on the supply tank not properly stopping the flow of water into the basin resulting in it overflowing. Mine is doing the same thing and I am trying to find replacement parts.
Jan 22, 2015 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Idylis S55C-AE1 humidifier leaks water on floor
My idylis humidifer is lealng where you put the water canister, after about 15 minutes from starting unit
Feb 26, 2014 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Will not power on
Throw it in the trash and buy you a better one !
Nov 10, 2013 | Idylis 2.5-Gallon Ultrasonic Humidifier...
Apparently no power to solenoid- using Carrier furnace
Check the humidity control dial for being defective. Turn the dial to maximum, and see if you have power. If you have an electrical volt meter check for power, on the input side of the humidity control. If no power is detected than the furnace control relay is suspect, and will require professional help.
Jan 12, 2011 | Aprilaire Humidifiers
Aprilaire 760 humidifier. no power to humidastat
the 760 send power out the humidistat is just a switch if you touch the two brown wire coming outof the 760 the humidifier should come on if it doesnt and you had appiled power to those wire you probably shorted the 760 control board
Jan 15, 2009 | Aprilaire Humidifiers
No/intermittent power to pressure switch
I would check the relay to be certain that it's getting power. That pressure switch is only controlled by the relay controlled by the thermostat.
Jul 16, 2017 | Honeywell Power Humidifier: Furnace...
Idylis 2.5-Gallon Ultrasonic Humidifier IHUM-20-25 Logo
Top Idylis Humidifiers Experts
Mack Baxter
Dennis
Are you an Idylis Humidifier Expert? Answer questions, earn points and help others
