Question about Frigidaire FRT15B3A Top Freezer Refrigerator
Whirpool WRM38Q refrigaridor defrost not working
Whirpool WRM38Q refrigaridor defrost system not working
The fan inside the freezer on my Whirpool ed25cq is running loudly. Does it need to be replaced?
Check for a build up if ice on the freezer compartment back, if there is the defrost system may be faulty
Feb 20, 2017 | Whirpool Refrigerators
I have a 2002 whirlpool fridge and a 2006 whirpool fridge, are the defrost controllers inter changeable?
Defrost controls are always being updated and I don't recommend using one from an older model. I really don't know if they will work and would be affraid to try if it were me. Thanks Sea Breeze
What are the model numbers?
Dec 21, 2012 | Refrigerators
We recently purchased a used side by side Whirpool fridge, model number ED56TNXMQ. It worked great for a few months but now the refrigerator side has stopped cooling. The freezer is still working but...
There is no simple solution. You can get it to work for a while, if you defrost the freezer to clear the ice out, but the bottom line is that something in your defrost circuit is not working correctly. And you will need to test the circuit to find out what isn't working correctly. Here are some links on how to test the different components of your defrost system:
The defrost heater is easy to check with a ohm meter. http://www.acmehowto.com/howto/appliance/freezer/check/defrostheater.php If you have continuity, then it is good.
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html is instructions on how to test the timer.
http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosthermo.php is instruction on how to test the defrost thermostat.
Hope this helps solve the problem.
Jun 15, 2011 | Whirlpool Refrigerators
Our whirpool refirgerator and freezer arent getting cold despite putting controls on highet setting?
Is there frost in the freezer? If so defrost it completely. I mean completely because most of the the ice that is built up is inside the freezer wall and blocking the air flow through the evaporator. Setting it to max when it has frost already only makes it worse as it is. So go ahead and defrost it completely then set the temperature to about midway only.
Feb 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirpool f/freezer keeps breaking down
Hi, this is a module fault.
Look to have the module repaired on a big auction site.
hope this helps
Sep 20, 2009 | Refrigerators
Cooling side of fridge not cooling
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrig. section not getting down to proper temp.
Hi Ron,
That was excellent description of the problem! Nice diagnosis, too!
The Adaptive Defrost Control board is located in the control section. It's part # is 4388932. I made this little diagram for you to assist you in gaining access to it.
Let me know, if you have any trouble, OK? Otherwise, don't forget to rate this solution and thanks for using FixYa!
SG
Apr 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer ok(Whirpool -6 yrs old), but the fridge is not cooling sufficiently, only around 50 degrees. A lot of frost build up in the freezer. Have to thaw it every couple of days.
defrost system not working. take back panel off inside freezer.
check continuity thro the defrost element and stats mounted on the pipework
if all ok then points to a fault with timer or module
Sep 09, 2008 | Refrigerators
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
