Question about Whirlpool LHW0050PQ Front Load Washer
Keep getting eo1 and f08 but water supply is not clogged
Every time we try to wash clothes, it stops and says "eo1 and fo8 it says something about water supply but there,s no clog
aborcass
  • 2651 Answers
SOURCE: A display of hf, and the water intake piece
no way to unclog other than removing sedimet from screen assy. internally nothing need to replace.inlet watervalve 1 piece for both hot and cold water.
Posted on Mar 15, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool duet Model ghw9200lw
The errrors are generally related to one another. The "F02" error is a slow drain problem. The "SUD" gets generated because it senses air in your drain pump (due to a possible blockage). More than likely you have an obstruction in your drain pump and you will need to clean it out. This is probably the reason for the pump sounding strange too. The following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Follow the link provided and this should be a an easy process for you. Keep in mind, however, that if there has been something obstructing your drain pump for any significant length of time, you may have damaged to pump. It doesn't take much to cause irrrepairable damage (I know, its a crappy design). If you clean out the drain pump reservoir, and the error(s) reappear, you will have to replace the drain pump.
If you require a replacment pump, you can purchase a new one on line at searspartsdirect.com. Just type in your model number and the pump can be located under the "Pump and Motor Parts" heading as item number 10 (part #8181684). For instructions on how to replace the pump, follow this link:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Hopefully, it won't come to the point of replacing the pump, but you have the information if you need to. I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 30, 2008
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Calipso Clothes Washer (yea, that
SUDS LOCK:
The motor controller senses a suds lock condition by analyzing the current draw on the drive
motor. If a potential suds lock is detected, the control tries up to 3 times to clean out the unit
with a mini-cycle. See Use and Care Guide for more information.
“SL” is displayed if suds are detected but the unit is unable to clean out suds. This may
indicate a bad pump, an extra heavy load, excessive detergent or excessive suds.
Press STOP/CANCEL to clear the display. MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 13, 2009
  • 289 Answers
SOURCE: water leaks from the detergent dispenser. Looks
pull the dispenser out and push down on the tab to remove the dispenser.clean the dispenser.
Posted on Jan 24, 2010
  • 353 Answers
SOURCE: Whirlpool Duet ghw9100lw1 will fill with water but
check pump filter
Posted on Mar 02, 2010
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
How do I fix error code f08 on a zanussi zpb 120 built in oven
Fo8 is heater fault. Check element first
Nov 17, 2014 | Ovens
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
Won't go through cycle eo1 keeps flashing
eo1 error means the main wash motor has either failed or has something blocking it.So your wash motor needs to be pulled out & cleaned or replaced.
Feb 18, 2011 | LG 24 in. LDF 7811 Stainless Steel...
The code nf keeps coming up what does that stand for
NF(No Fill) code indicates that the washer is not getting enough water supply. Check if wwater supply is turned On and water is coming through the pipe. Then the fill valave can be clogged. t can become clogged with sediment over time
Stop the water supply and then remove the hose and then check for any clogs and if they are fine then in your case most probably your fill valve must have gone bad for this problem.Replacing it must solve the issue.
Jan 14, 2011 | Samsung WF337AA Front Load Washer
Fo8
Error code F08 is indicating that the heater relay is not being activated.
F08 error code for Hotpoint washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
You need to check all the connections on the module, the pressure switch, and the heater element.
I hope this help to solve it; remember to rate this answer. Nice weekend.
Oct 02, 2010 | Washing Machines
My hotpoint ultima keeps triping the trip switch. it had f08 on the screen but now that has gone, but still trips electrics every time i press start.
Hi
f08 means heater relay cannot be actived so try unplugging heater element and see if it stops tripping the electrics.
regards
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Machine fills and agitates, but won't drain
It sounds like you pump is clogged. If there is something stuck in your pump the motor can't spin it to drain the water. If that is the problem then it's easy to fix. Simply clear the pump and put it back on, just make sure to clamp off the hoses to the pump with hose clamps or you will have water every where. If that is not the problem though then it means that your timer is bad and that is a little more expensive. Try the pump first though and hope that that is all it is. If not, like I said, you will need a new timer but most likely your pump is just clogged with something that is causing the pump motor to not spin. It could be a coin or a hair pin or even a sock or something. Good luck and let me know if you have any other questions.
Jan 16, 2009 | Kenmore 22422 Top Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
11 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
