Placing metal sheets back into an office essentials LMA806 laminator
Paper burnt inside, I pulled machine apart. Can't work out how to put the 2 metal sheets back together.
checkitright
  • 1362 Answers
SOURCE: A laminating sheet is stuck
OOOOooooooooohhh!!!!!
Hate to tell you, BUT, the laminate is melted on the fuser. You learned the hard way, htere are specific laminates for different types of machines, the reason is because of the amount of heat it can tolerate. If you look in the back of the box it will tell you what machines they are good for, if yours is not listed, you should look at the manual or the website.
You will have to take it apart and remove the melted plastic, with hopefully minimal damage to your machine, otherwise the fuser will need to be replaced.
Posted on Sep 05, 2008
Joed911
  • 4338 Answers
SOURCE: HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Oct 01, 2008
multilinkent
  • 739 Answers
SOURCE: I've pulled the laminator apart
hi..
i thing u should see this manual
CLICK HERE
hopefully this will help solve yr problems
regards
Posted on Jul 14, 2011
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
liujhwbrfwe
SOURCE: The last time I used
I found manual on amazon, so take a look there: Amazon com thermador manual I hope this was helpful. cheers
Posted on Nov 30, 2014
How do I get laminating pouch out that has rolled up inside the machine?
pull the machine apart and remove the melted plastic from the roller
basically laminators are so cheap the it is quicker to junk it and get a new one
Feb 23, 2016 | Office Equipment & Supplies
A laminate and paper jam in a Gbc HeatSeal H425 Laminator
floating cowboy
Jun 26, 2012 | Gbc HeatSeal H425 Laminator
Laminator Jammed! I have a fellowes saturn 125 laminator. there is an item stuck inside that is not sticking out on either side, so cannot be pulled out, even when the reslease lever is pushed. can i...
once you take it apart it voids all warrants if you have any.
if you do not have any warrant parts than that the only way you are going to fix the issue.
here is what some one gave me some tips on disassembly of equipment. draw a picture of the device, mark the area of screw layouts, after separating the 2 parts draw diagram of each part, make foot notes on what you did, screw locations, parts removed, parts cleaned, PUT EVERYTHING IN A LINE IN THE ORDER OF REMOVAL PARTS, than work backwards and put everything back the way you took it apart, you should not have any extra parts and it should work fine. than if it every happens again you have your notes and information on hand to help you. you could try this site.
www.ask.com/
www.manualonline.com/
/mfg.name/make/model#/
www.mfg.name.wow/manuals/service/
www.manuals.wow.com/make/model#/service/repair/
www.disassembly.wow.com/mfg.name/make/model/instructions/
Mar 22, 2012 | Fellowes Saturn SL 125 12.5-Inch Laminator
DO YOU HAVE A MANUAL
I do not have a manual for that laminating machine. Over the years I have used a number of different units, and dismantled a few as well.
Essentially to use it, you let it warm up, and if you are pulling the laminate off a single roll, it should be folded over on itself, you roll an edge to see which side opens and slide in the item you want laminated.
The one thing that may be a source of bubbles in the finished product is you need to lightly roll a perforator over the item to pierce the laminating plastic so air can escape. Also make sure to have about 2 inches of extra palstic at each end for consistent results.
Feed it in straight, that 2 inches will allow you only a little room for adjustment- if at all possible, just feed it in, supporting the document so it does not flop over, and once it is feeding, you can see it come out.
Because it is nothing more than a heating element, and in the case of the smaller types, it is just a long halogen light bulb for the heater. It will always smell hot when in operation, because it is, and small amounts of plastic do peel off from time to time. So it is susceptable to damage if jarred while heating or in operation, and the tube can break if the laminator hits the floor.
To clean rollers of the laminator, normally they have a cleaning sheet, but not always, and if you do not have one, you can improvise by taking a section of craft paper bag, fod it over and trim to width of the laminating material. Feed it through and once it feeds, with gentle resistance held against the paper, this will help clean the rollers. Once through, open and refold so the inside is now outside and feed it through again with same procedure. Repeat with a new sheet until it feeds through clean.
If unit does not heat, check fuse if it does not turn on at , no motor, no light; and It may be an internal fuse on a circuit board. There is also a thermal fuse in the heater circuit as well- these can fail if the unit is left on all the time and not used. They should be powered down between uses. The exception is the industrial sized laminators used by many of the office supply stores as they take a while to heat. Otherwise the lamp is the chief suspect for no heat. If you plan to service it at hone, or to at least check the condition of the ttube, with an Ohm meter, you should be able to measure across the filament. It should be less than 20 Ohms resistance. Finding a replacement halogen is not cheap, and it may just be more cost effective to replace unit than try repair it if you are in an office type setting. It also requires you wear cotton gloves so not to leave any trace of oil or contaminant on the glass as they will fail at that point if there is any oil or other residue.left on tube when it lights up.
Jan 10, 2012 | Scotch 9" Tl901 Hot Laminating Machine /...
Guess I'm not too bright. Have a pack of GBC SelfsSeal Laminating Sheets, 9 x 12. Instructions say "Center item face sown on the clear non-adhesive." "Peel away the liner and...
It's not you, it's the instructions. They are just wrong and will not work as directed. However, I have found a way to use these sheets that works for me, but it is still not particulary easy.
Step 1) Lay the 1st sheet on a flat surface, adhesive side up. Pressing down on the small 1/2" strip of backing, peel away the large backing sheet exposing the adhesive. Holding the sheet you want to laminate face down and at an angle to the work surface, carefully align the material by "bumping" it up against the edge of the 1/2 strip. Once aligned, carefully and gradually lay the item onto the adhesive. Like I said, not particularly easy, but if you are careful, it will work.
Step 2) If you want to double laminate, which I usually do, the second laminate sheet seems easier to me. Leave the Step 1 laying flat on the work surface. Take a second lamination sheet and again, hold it down on a flat surface and peel away the large backing sheet, leaving the small 1/2" backing attached. Take this 2nd sheet and holding it over the 1st, face down and angled up from the work surface, align the 1/2" strips of both sheets together and again carefully lay the 2nd sheet over the first single-laminated item. The two 1/2" strips don't stick to one another allowing a bit more flexibility for alignment.
Press all of this together and work out any bubbles or wrinkles. Once that is done, pry the two sheets apart at the very edge to remove the two 1/2 strips.
Unless you are incredibly lucky the edges will never align 100%. I use a paper-cutter to trim off any irregularities after I finish laminating.
Apr 11, 2011 | Gbc Selfseal Letter-size Laminating Sheets...
The sheet im laminating rolled up inside, cannot get it out
Water-based cleaners will not work with this type of adhesive. Rubbing alcohol or a citrus-based cleaner (eg, Goo-Gone) will be required.
Feb 22, 2011 | Xerox Staples XRX LM1910 Laminator
Have a used Fellowes EXL a4 laminator. Need a manual or instructions for use. Thanks.
Set- up
The only assembly required for an @Home laminator is attaching the wire support rack, which ensures that the sheets coming out of the machine cool in a flat position and do not curl. Using the illustration on the inside of the manual cover as a reference, push the ends of the rack " into the holes ! in the back of the machine as far as they will go.
Operation
Your laminator works by means of two rollers, one on top of the other, each turning in the opposite direction to draw a plastic, open-sided pouch coated with adhesives through them and out of the machine. Understanding this simple mechanism will help you decide what materials you can laminate without risk of damage to your machine. You can feel confident laminating all materials that are flat and dry, for example, but should avoid those that:
• Contain liquids, gels, or even moisture, that could escape
• May crumble or otherwise disperse under pressure, or
• Are likely to break, as could glass or rigid metals and plastics.
With hot lamination, where the rollers are also heated, make sure you don't put anything into the pouch that could melt and leak into the machine.
Once you have checked the suitability of your contents, you need to decide whether to use cold or hot lamination. Cold lamination, also called self-adhesive lamination, bonds materials between an adhesive and a non-adhesive sheet solely by means of pressure. As a result, this method tends not to produce as tight a seal against water and the elements as
hot lamination, but can be useful for heat-sensitive materials, such as thermal paper or fragile documents. While the cold method used to be the only good way to laminate photographs, today's heated-roller technology enables you to achieve excellent results and is therefore probably the better choice.
5
The contents and the mode decided, the next step is to choose the right pouch for the job.
Hot and cold laminating pouches are especially designed for their separate purposes and cannot be substituted for one another. When it comes to pouch size and thickness, you should make sure that the one you buy is no wider than the entry # of your model and not thicker, together with the contents, than the capacity of your machine. If you are laminating paper of a standard size and weight, you can quickly see your pouch thickness options on
the selection guide stored under the machine:
• White and gray boxes indicate that the pouch/paper combination can be used
• No box on the table indicates that there is no combination possible with your machine.
If you find several pouch options for your document, take the one that best suits the purpose:
The thicker the pouch, the more rigid and resistant the laminated sheet will be. If you are not sure of the paper's weight or are laminating other materials, the combined thickness of the pouch and contents should be your guide. The maximum in this case is the equivalent of a stack of 6 to 7 sheets of standard office paper. (See Product Profile for details on capacity limits.)
If even the smallest size pouch will leave a lot of space around your contents or you want the lamination to conform to the shape of your contents, wait to cut it to size until after lamination: a laminating pouch is precision-cut to ensure minimal leakage of adhesives, and this cannot be replicated with scissors or a paper-cutter. You'll also find the pouch easier to cut when it is hardened.
How you arrange your contents in the selected pouch is important in both cold and hot modes. To produce professional-looking results and ensure a long working life for your machine, follow these simple guidelines (see illustration on the inside of the manual cover):
1. Lay contents as close as possible to the sealed edge of the pouch, which is the end you will be feeding into the machine. If the material is more than 1 cm or 1/2 inch from this edge, the rollers will not have enough traction to draw in the pouch and will turn continuously without advancing it.
2. Arrange multiple items close to each other in the pouch, with the edges no farther than 1 cm or 1/2 inch apart. If there is a larger gap between items, the rollers will slip into it and lose their traction. As above, the rollers will turn without advancing the pouch.
3. Leave a free margin around contents of at least 3 mm, or 1/8 inch, on the three unsealed sides of the pouch to guarantee a strong seal. This is a minimum, meaning you can have as much margin beyond this as you wish.
To begin laminating, place your machine on a work surface where you have enough room at the back to allow the full length of the pouch to clear the material exit '. Plug in the machine and press the power button &, which will start the rollers turning. If you plan to do laminate both cold and hot in one session, it makes sense to start with cold, so you don't have to wait for the machine to cool down. (This can take one to two hours.)
In either case, to save energy and reduce wear-and-tear on your machine, turn off the machine as soon as you are finished by pressing the power button &. If you forget, however, the machine has an automatic switch-off function, which causes it to turn itself off one hour after not being used.Cold Lamination
With the contents and the pouch you have selected at hand:
1. Turn temperature selector $ to . The machine will indicate its readiness by turning on
the green standby light % and giving an audible signal.
If the machine is at room temperature, this will be almost immediate.
2. Place contents in pouch in line with the guidelines (p. 5). Lay the pouch on a flat surfaceand open it so that the adhesive side, which is covered by a glossy protective sheet, is vertical.Place the contents face up onto the transparent, non-adhesive side, but do not closethe pouch.
3. Insert sealed edge of the open pouch into the entry, as
shown, bending the protective sheet backwards over the
machine and grasping its free edge. As the machine draws
in the pouch, keep holding on to the protector, which will be
peeled away from the adhesive side as the pouch moves
through. Although it is easier to take off the protector and
close the pouch before you feed it in, you will create air bubbles
and other irregularities that the machine will not be able
to even out.
The finished sheet will emerge from the material exit ' by itself. Remove it from the support
rack only after it has completely cleared the exit.
Hot lamination
1. Turn temperature selector $ to or . The boxes in the selection guide you used to
choose the pouch size and thickness also indicate what temperature setting you should use
with your pouch:
• If the box is white, use ,
• If the box is gray, use .
If you are not sure of the weight or thickness of the contents or pouch, you will avoid possible
damage if you start with the lower temperature. With the lower setting, the machine will take 5 minutes to warm up and with the higher, one minute longer. When the laminator has reached the setting you chose, it will indicate its readiness with a green standby light % and an audible signal.
Unlike with cold laminating, the contents can be face down or up within the pouch. Close the pouch once the contents are arranged.
3. Insert sealed edge of the closed pouch into the entry #,
as shown, and release it as soon as the machine begins
to drawn it in, as shown in the illustration.
itself. Remove it from the support rack only after it has completely cleared the exit.
7
Maintenance
To keep your laminator free of adhesives that could hurt the quality of your work, you should clean the rollers from time to time, or frequently, depending on how often you use the machine. The best way is to do this right after you have finished hot laminating, because the rollers will still be hot, which is necessary for the cleaning process.
To clean the rollers:
• Turn selector to if it is not already on this setting
• Wait for the readiness light and signal
• Insert the cleaning sheet included in the package, repeating one or two times
• Insert a plain white sheet of paper to test for remaining traces, and
• Reinsert the cleaning sheet, if necessary, and retest.
To clean the exterior of your machine, just wipe with a soft cloth dampened with plain water.
Dec 15, 2010 | Office Equipment & Supplies
A laminating sheet is stuck inside machine. You can't see it from either end and machine smokes when turned on now. It is a Fellowes EXL 125-2.
Sep 05, 2008 | Office Equipment & Supplies
Paper jam!!
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
k24674
jasbo
jasbo
