Question about Sharp AR-207 Copier
Sharp AR-207 The machine will not power up?. I used it on Wed. afternoon everything seemed fine, then I turned off the power and on Thur. morning when I turned it on it went through its worm up cycle?, then it powered down and will not power up at all. I have tried changing where it is plugged in at although, the other items plugged into the surge protector stil have power and work fine.l
  • 24 Answers
There is a fuse that blows on the power board, most electronics store will sell you one for next to nothing
Posted on Mar 15, 2008
  • 790 Answers
Hi
Can you tell me what is your exact Complaint in to your unit?
Posted on Oct 29, 2007
  • 70 Answers
I am sure that I don't have to say check the power switch, so you probably have a bad power supply, either not enough voltage, or maybe there was a strong enough surge to knock it out.  Needless to say, if it's under warranty, you should get it serviced.  If not, it'll probably be too costly, and would warrant a new machine.
Posted on Oct 27, 2007
Sharp AR 207 paper gets lifted out of tray but will not continue to feed into machine. Side feed works fine
try cleaning the paper feed rollers in (above) the tray. and the rollers on the right side (theres 3 gray rollers) If thats works you will need to replace the rollers soon.
Aug 28, 2010 | Sharp AR-207 Copier
Toner explosion
You need to either replace the toner cartridge or empty the sump on the front of the cartridge. The waste sump is in the front of the toner cartridge, It has filled up and has nowhere else to go but out of the sump and where ever it lands. Sometimes they fill up before the toner cartridge is empty. It happens
Jul 30, 2010 | Sharp AR-207 Copier
I have a Sharp AR-M207 Copier , it has H2-00 on the display , how do I fix this .
Perform the following procedure to enter the simulation mode.
"#" key “*“ key "C" key “*“ key then enter 14 press start machine will switch off then on
Feb 02, 2009 | Sharp AR-207 Copier
Sharp AR-207 copier puts .5 inch black line across entire bottom of copy
does the line only show up when making copies from the adf or both when you put it on the glass. if only when thru the adf the **** glass is dirty. that is the glass that is only about an inch wide. be carefull of the two pieces of tape that are on both the front and back of that glass they fall off easly.
Oct 18, 2008 | Sharp AR-207 Copier
Sharp error code U2
you can get rid of this u2 by pressing buttons as follows: # , interrupt, C, interrupt sequentially. then enter the no. 16 and press the start button. good luck
May 15, 2008 | Sharp AR-207 Copier
Sharp AR-207
sounds to me that the power supply has blown, or fuse onthe power supply. If you remove the left side cover you will see the power supply. Please unplug the machine first. check fuses if they are good, the power supply is bad.Let me know if you need more help.
Oct 26, 2007 | Office Equipment & Supplies
Sharp AR-207 Copier Logo
55 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
